B5S4 front brake upgrade for B6A4
Great bang for the buck braking upgrade! no modification needed to run these on a b6a4 platform. go from your stock 288mm to 321mm.
this is everything that you will need to bolt on and go minus lines. but you can use your stock ones. so that means you get: Calipers, rattle clips, carriers, rotors, and pads. set up is in good condition. could use a paint job to fit your liking. pads have 40% life left. still have alot of braking power. buyer pays for shipping via USPS. if i can get it all to fit in one box then it should be cheap. PRICE IS $190+ SHIPPING i have good feedback on audizine.com under the same name if you choose to look me up |
So this is a no go on a b5 a4?
I wouldn't see why not. I believe they use the same spindle with the same bolt pattern
