FS: Parting out B5 1997 A4Q 2.8L Auto Blk/Ecru
Best way to contact me is DIRECT at MPLSChase@gmail.com Please put the Year, Model and Part you are inquiring about in the Subject...THANKS!!!!!!
Prices do not include shipping
Pics Available upon Request.
If you don't see it….Ask, I probably have it!!!!
Car has Black Exterior with Ecru (Light Beige) Interior - Had 137K Miles
Engine
Engine 2.8L Code "AFC" - $800
Motor Mounts - $40/Ea
A/C Compressor - $50
A/C Condensor - $50
Starter - $50
Alternator - $50
Oil Cooler - $30
Brake Booster - $60
Brake Master Cylinder - $60
Brake Fluid Resevoir - $25
Differential - $100
Axle Rear - 2/Ea $25/EA
Axle Front - 2/Ea $25/EA
Radiator - $50
Rear Hubs - $50/Ea
Belly Pan - $40
Exhaust System - Stock - $100
O2 Sensors - $40
Rotors - $20/Ea
Coolant Resevoir w/sender - $30
Wiper Motor - $30
Shift Linkage (5sp) - $30
Air Filter Box - $30
Air Filter Box Ducts - $20
Fuel Pump - $125
Drive Shaft w/Carrier Bearing - $100
Brakes/Suspension
ABS Module - $125
ABS Pump - No Module - $50
Brake Calipers - (4) $40/EA
Brake Booster - $20
Brake Master Cylinder - $20
Front Rotors - $15/Ea
Rear Rotors - $15/Ea
ABS Sensors $50/EA
Tie Rod Assys- $40/ea
Suspension - AFTERMARKET KONI FULLY ADJUSTABLE- $600 (4 Shocks/4 Springs)
Control Arms $40/ea
Differential - $100
Axle Rear - 2/Ea $40/EA
Axle Front - 2/Ea $40/EA
Rear Hubs - $50/Ea
Exterior/Body/Lighting
Trunk - $100
Door DS Frt - $100
Door DS Rear - $100
Door PS Frt - $100
Door PS Rear - $100
Hood - Not Available
Fender Liners - $20/Ea
Door Mouldings Mid (Emerald Green) - $40/Ea
Moon Roof Assy Complete (Glass) - Ecru Interior Shade - $150
Sunroof Motor - $75
Rear Bumper Cover - $150
Rear Bumper Shocks - $40/ea
Door Weather Stripping all four doors - $20/EA
5 Spoke 16" Wheels 5 x 112 Good Condition With 80% tread (Nokian's)- $250 (Set of 4)
Interior/Electrical/Stereo
Climate Control - $40 (works, missing 1 LED bar on left screen)
Central Locking Pump - $75
ECU - $100
Shifter **** Black Leather - Not in good condition
Shifter Boot Black Leather - $25
Radio - Bose Delta with code- $75
Bose Speakers - $40/ea
CD Changer - $80
Bose Amp - $50
Pillar Trims A,B,C (Ecru) - $30/ea
Headliner with Sunroof Opening (Ecru) - $100
Trunk Carpet Complete (Black) - $40
Interior Carpet (Ecru) - N/A
Dash (Black) - $100
Sunroof Switch Panel w/Lights (Ecru) - $50
Front Driver's Seat - N/A
Front Passenger Seat - N/A
Rear Seat Ecru - N/A
Center Console Black (no Armrest cover) - $30
Door Pulls Ecru (no switches) - $30/Ea
Sunvisors (Ecru) - $25/Ea
Column Switches $30/ea
Window Switches - $10/Ea
Door Handles Black/Silver Good Condition - $30/Ea
Sunroof Motor - $75
Kick Panel - Driver's Side - $20
Heater Box Complete w/Heater Core, A/C Eaporator and Fan Motor - $100
Rear Window Deck (Ecru) w/3rd Brake Light $50
Tilt Steering Assy. w/ignition and Key - $75
Center Heater Vents - $15/Ea
Side Vents - $15/Ea
Rear Vents - $15/Ea
Overhead Grab Handles (Ecru) - $10[/align]
Engine
A/C Condensor - $50
Starter - $50
Alternator - $50
Oil Cooler - $30
Brake Booster - $60
Differential - $100
Radiator - $50
Rear Hubs - $50/Ea
Belly Pan - $40
O2 Sensors - $40
Rotors - $20/Ea
Wiper Motor - $30
Fuel Pump - $125
Brakes/Suspension
ABS Module - $125
Brake Booster - $20
ABS Sensors $50/EA
Control Arms $40/ea
Differential - $100
Rear Hubs - $50/Ea
Trunk - $100
Door DS Frt - $100
Door DS Rear - $100
Door PS Frt - $100
Door PS Rear - $100
Sunroof Motor - $75
ECU - $100
CD Changer - $80
Bose Amp - $50
Dash (Black) - $100
Sunroof Motor - $75
Side Vents - $15/Ea
Rear Vents - $15/Ea
RE: FS: Parting out B5 1997 A4Q 2.8L Auto Blk/Ecru
Still have many good parts left...Email direct at MPLSChase@gmail.com and let me know you saw it on Audi Forums...
Thanks!
Thanks!
Bump
need headlights switch
ORIGINAL: a4BRZLowrider
Email me direct at MPLSChase@gmail.com
Thanks!
Chase
just send both left side.. isn't a one piece??
Bump
Can I score that 02 sensor off of you and also the door molding thanks.
Lots of parts left!!!
