Go Back  AudiForums.com > Audi Classifieds > Wheels/Brakes/Suspension
FS: Stoptech 332x32 BBK for B5 A4, needs work, $750 shipped >
Wheels/Brakes/Suspension List your Wheels/Brakes/Suspension parts for sale within.
Old 09-17-2011, 06:30 PM
Default FS: Stoptech 332x32 BBK for B5 A4, needs work, $750 shipped
I put stock calipers with new pads and rotors on my car. This came off a B5 A4 quattro, not sure if it will fit a B6 but I'm pretty sure they have the same calipers/brackets. Aside from needing new pads, the calipers on this kit could use some work. They had started to develop a creaking sound which was the calipers hanging up a bit. The car would pull to the left under hard braking because the right side was worse. It would also cause the ABS to sometimes kick on when it wasn't necessary and for the light to come on because one side was doing more work than the other. Since the inner pad on the passenger side wasn't making full contact, a small part of the rotor became rusted from not touching the pad under braking. The rotors should be turned because of this. Finally, since I had to use a little heat on the brakes lines, the rubber peice at the end melted a little. None of the clear rubber that covers the Stainless Steel line itself melted and this will in no way affect the kit other than cosmetically.
This kit goes for $2200 on ebay. It has black ST-40 calipers and slotted rotors, they are not drilled however. Comes with SS lines too. The rotors are about 13", a 17" wheel will clear, you may need spacers though.
The brackets are still on the calipers and I will include 4 extra bracket bolts. The kit simply re-uses the stock ones but I have 4 extra for anyone just in case.
The calipers need some work, it needs new pads, and the rotors need to be turned so I am asking $750 shipped. Feel free to call or text, Jeremy @ 716-380-5426.
This is the melted rubber at the end of one of the lines
Driver side caliper/pads
Driver side rotor outer
Driver side rotor inner
Passenger side caliper/pads, you can see the outside pad is much more worn than the inside one
Passenger side rotor outer
Passenger side rotor inner
Old 11-06-2011, 01:05 AM
still have these
Old 11-22-2011, 08:36 PM
How about $600?
Old 12-18-2011, 09:55 PM
WIKEDA4's Avatar
also curious if still up 4 sale
Old 01-17-2012, 11:08 PM
still have these
Audiable
02-23-2015 10:13 PM
dzantonn
04-14-2009 11:14 PM
Jeff
04-28-2006 08:29 PM
tip5
12-11-2005 03:25 AM
Quick Reply: FS: Stoptech 332x32 BBK for B5 A4, needs work, $750 shipped
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
