Need Rotors
Need Rotors
I have a 99' A4 1.8T Avant Quattro. I need rotors all the way around. Does anyone have some? I would prefer cross drilled or slotted, but at this point I am desperate. Bolt pattern is 5x112.
Im guessing you are looking for a set of used or second hand rotors, or someone offering you a deal, however there are some zimmerman x-drilled rotors i bought off pelicanparts.com. If you are not building a track car i would suggest buying brembo blanks instead of x-drilled. x-drilled can warp, crack or cause a vibration when braking. although if you get quality x-drilled or slotted they just look nicer. but try pelican parts or even tirerack.com
I have a set of 4 rotors and calipers off of an 2000 S4, not sure if they will work and shipping used rotors would be expensive but they are in good condition, I could make a great deal on the calipers and rotors if they will work for you.
Thanks,
Chris
925-330-2025
Thanks,
Chris
925-330-2025
Thanks for the link. I am going to go with those. Chris, thanks for the offer anyway. I appreciate it.
adamsrotors
06-25-2015 02:33 PM
adamsrotors
06-25-2015 02:31 PM
adamsrotors
06-25-2015 02:17 PM
adamsrotors
B8 Models
15
06-25-2015 02:08 PM
adamsrotors
06-25-2015 02:03 PM
