Part outs: 2 s4s - 1 01 silver 6 speed s4 stg3 93k, 1 02 santorin blue s4 Tip 112k
PLEASE PME ME to BUY OR ASK QUESTIONS!!!
Millions more pics on my vortex ad:
VWVortex.com - Part outs: 2 s4s - 1 01 silver 6 speed s4 stg3 93k, 1 02 santorin blue s4 Tip 112k
Up for part out are 2 vehicles - 1 silver 6 speed stage 3 s4 93k, other one is 1 02 santorin blue tip 112k vehicle. First time i have posted 2 cars at once but thought itd be easier. The santorin car is parted and off to its final resting place. The silver car is 1/3 of the way done and will progress through the weekend to hopefully full completion. Please take a look at all of my parts and lists. I spend a lot of time making this list and updating sold components as well as extensive pictures. I have pics of just about everything. If I missed something please pm and ask. If your want random bolts, wiring snippets, or little parts let me know. I am happy to help. Unfortunately shipping is 5 dollars at a minimum so many times I will provide stuff at close to free if you buy it with something else I can just add it into that box.
Large bulky or fragile parts are shipped via greyhound bus which will require you to pick up at your local bus station which can be found here: Greyhound PackageXpress - Locations
I will ship these via fedex if you dont want to pickup at your local bus depot but I wont be held liable when fedex destroys these fragile large items as they have in the past.
Prices almost all include shipping. Most items will ship in 1-2 days via priority mail or fedex. Dependent on location, size, weight, and cost. Some odd items or not yet pulled items may take longer again dependent on various things. Shipping is non-refundable under any circumstance.
Pickup is welcome in PA 16803 and will save you the costs of shipping making the items cheaper. Cash on pickup. Paypal, amazon payment, or google checkout for shipments is usable.
Happy purchasing, thanks for looking and I appreciate your business. I am sure PSU appreciates it as well when I hand it over in tuition lol.
I will be adding more pics off the silver car once the car is close to done or on its way to being out the door.
Please keep in mind many items are multiples of each other in stock and various colors are available from prior part outs. Just ask. So while only one may be listed or pictured that doesnt mean I dont have more available for the rest of you.
Upgrades/Mods available:
rs4 pressure plate, 6 puck sprung hub disc, TO bearing (unknown manufacturer) looks to be in great shape with plenty of meat left 300 shipped.
oem rs4 clutch kit 250 shipped
BW used genuine k04 turbos 1500 shipped or 1450 picked up
oem rs4 inlets 300 shipped 290 picked up
APR stage 3 fueling setup - RS4 airbox, rs4 maf housing, rs4 maf sensor, rs4 pigtail, rs4 injectors with spacer hats, APR tuned ECU, rs4 accordian hose 975 shipped OBO
Blitz boost controller with all wiring, boxes, display and controls, etc. complete
H&R coilovers 850 shipped - like new - 800 picked up
K*N panel air filter 25 shipped (2 available)
SPP tip mod and MOMO shifter 35 shipped
VAST log style manifolds 700 shipped OBO
Red Samco TBB with clamps 45 shipped OBO
Neuspeed Stainless Steel Catback 3 inch single exhaust 550 shipped or 450 picked up
AWE or APR SS downpipes with catted mid sections - havent pulled yet not sure which ones are there yet so price TBD
Hagus m3 style mirrors with blue glass 100 shipped
Engine and driveline:
Complete 2.7T engine with wiring harness. Picture unbolting the trans and downpipes and thats what you get. Pretty much everything. 1000 picked up or ~1200 shipped depending on location
Complete 6 speed O1E tranny swap package: includes eveyrthing needed to swap. Can modify if you already have a manual as you wont need a few things: transmission, tranny mounts, tranny mount arms, slave cylinder, tranny sensors, shifter linkage, shifter, trans spacer, clutch fork, front axles, rear axles, driveshaft, rear differential, front uprights, pedal assembly with clutch master, interior wiring snippets, free flash to manual ecu coding/software 1800 shipped or less picked up
6 speed 01E transmission 1000 picked up or ~1100-1200 shipped dep on location
auto transmission 400 picked up or 750 shipped
auto tranny spacer plate 15 shipped
auto trans flex plate 25 shipped
auto trans crank hub bolt on spacer 10 shipped
01 E 6 speed transmission in good working used shape 1000 picked up
6 speed tranny arm mounts 65 shipped
front 6 speed manual axles 75 shipped each
front auto axles 55 shipped each
rear axles 45 shipped each
auto driveshaft 100 shipped
manual driveshaft 150 shipped
engine wiring harness less maf sensor plug 75 shipped
tranny mounts 10 shipped each
rear differential manual 150 picked up 250 shipped
rear differential auto 150 picked up or 250 shipped
pedal assembly 75 shipped manual or auto
bare 2.7t heads 75 shipped each
complete 2.7t heads 250 shipped each
SSAC catback exhaust 250 picked up
cam position sensor 15 shipped
front and rear 02 sensors 50 shipped each
egt sensors 100 shipped each (black and brown boxes available)
afterrun pump under intake manifold 75 shipped
map sensor 25 shipped
PS or DS k03 turbo 150 shipped or 300 shipped for pair
crank pulley/engine dampener 45 shipped
PS pulley 25 shipped
Mech fan clutch/plastic fan 55 shipped
just mech plastic fan 35 shipped
accessory belt 7 shipped
less then 5k used low mileage timing belt set 90 shipped water pump, thermostat, timing belt, tensioner roller, hyd tensioner, idler roller, tensioner arm, etc.
bare 2.7t block 150 picked up (for a build)
lower oil pan 40 shipped
upper oil pan 175 shipped
oil cooler/oil filter housing 45 shipped
TB up pipes/bipipe 40 shipped pair
y pipe 50 shipped
accordian hose 10 shipped
hitachi maf housings 15 shipped
stock airbox 50 shipped
ICM's 40 shipped each
crank/flywheel/engine speed sensor 25 shipped
oil level sensor 30 shipped
auto transmission cooler 15 shipped
condensor 100 shipped
axle or trans heat shields 15 shipped each or less combined
fan control module (under DS frame rail) 45 shipped
ground strap (engine to frame rail or battery to chassis) 7 shipped
diverter valves 15 shipped each
stock rubber DV hoses 10 shipped for pair with clamps
complete oem intake hose set (literally every single rubber intake hose on the engine for the whole tract) 45 shipped
2.7T crankshaft 75 shipped
2.7T valve covers 75 shipped for pair bare or 25 powdercoated your choice of color/finish
valley pan 20 shipped
cross over coolant tube assembly 50 shipped
condensor fan (in front of rad) 55 shipped
electric fan in core support 45 shipped
AC dryer 15 shipped
AC lines from chassis to lower left 45 shipped
full engine cover set (3 middle triangle pieces, 2 valve cover 5v pieces, air box cover) 75 shipped
individual engine cover pieces 10 shipped
big triangle piece 25 shipped
airbox cover 25 shipped
partially cracked spider hose assembly 25 shipped
PCV valves/pancake valve 15 shipped
complete valve train of valves, lifters, springs, retainers, and keepers 150 shipped (nothing wrong with it, just from an upgrade)
cam chain tensioner 100 shipped
cam chain 15 shipped
cam plug 7 shipped
cam gear 15 shipped each
air box snorkel (2 piece) 15 shipped
coolant tank 20 shipped
PS tank 10 shipped
ABS tank 10 shipped
vacuum canister under DS fender 10 shipped
battery (good used battery) 10 picked up
washer fluid tank 40 shipped
bumper squirter pump 10 shipped
windshield squirter pumped 10 shipped
suction pump under DS wheel well with filter 35 shipped
charcoal canister box under spare wheel tub 50 shipped
turbo inlet pipes 15 shipped each or 25 shipped pair
turbo outlet pipes 15 shipped each or 25 shipped pair
intercoolers pair 45 shipped or 25 shipped each
intercooler's shrouds 30 pair shipped or 15 shipped each
stock fuel pump assembly 50 shipped
metal turbo inlet pipes (upper ones that mount to lobster claw hoses and oring seal to the lower cast inlets) 25 shipped for the set
dual mass flywheel 75 shipped
straight piped 2.5 inch exhaust with polished tips cat back exhaust 25 picked up or 75 shipped
fuel pressure regulator 4 bar 25 shipped
fuel pressure regilator 3 bar 15 shipped
stock catback exhaustr complete 50 picked up or 100 shipped
Exterior:
Hagus m3 style mirrors with glass 100 shipped
silver Real Reiger plastic v3 rear bumper 150 picked up or 250 shipped (1 piece)
silver regier v2 sideskirts real plastic 85 picked up or 120 shipped
Silver painted CF VIS hood
silver complete trunk with custom rear lip 175 picked up or 250 shipped
DS mint oem HID headlight 150 shipped 250 with all bulbs and ballast etc
santorin trunk lid 175 picked up or 250 shipped
DS Santorin mirror housing 40 shipped
j caps chrome fuel lid cap with gas cap 20 shipped
DS mirror autodim glass in good used shape 60 shipped
PS mirror glass fluid leaked 15 shipped
Doors (I have many color available not just silver) each door shell is 50 picked up or 100 shipped
complete door wth all guts glass and motor etc is 100 picked up or 150 shipped
door glass 50 shipped
front and rear main glass is 20 picked up you pull it
front and rear main glass side press down seals 15 shipped a set
Silver hood 200 picked up or 275 shipped (prefer pickup on this)
silver trunk (its an a4 trunk but its the same nothing changes besides the badging) 150 shipped
silver s4 trunk 150 shipped
rear tail lights (smoked) 95 shipped complete with bulb holders, bulbs, tail lights, gasket, and bolts
rear tail lights (smoked with blue tint reverse sect) 95 shipped complete with bulb holders, bulbs, tail lights, gasket, and bolts
gas cap 10 shipped
gas cover 15 shipped (many colors available)
fender liners front 35 shipped each
fender liners rear 30 shipped each
fender side marker lights 15 shipped a pair or 5 a pair smoked
ecu box lower 15 shipped
ecu box upper 10 shipped
complete ecu box 20 shipped
cabine air filter assembly 3 piece 20 shipped
fake firewall cover set (4 piece set including moulding, big firewall cavity cover, small battery cover, and both wiper cowling pieces 80 shipped
large firewall cover by itself 40 shipped
wiper cowling (left and right) 45 shipped
wiper blades in good shape 5 bucks a pair with other item purchase or 8 shipped a pair themselves
wiper blade metal arms 10 shipped a pair
B pillar exterior shiny black covers 25 shipped a pair
trunk hinges (many colors) 25 shipped a pair
trunk shocks 13 shipped a pair
hood strut/shock 20 shipped
washer squirters nozzles 25 shipped pair
core support 165 shipped
headlight mounting tabs/brackets (near rad on core support) 20 shipped pair
front or rear bumper shock 45 shipped pair
PS cooler loop assembly 15 shipped
front chassis oem strut bar and side brackets 75 shipped
front hood hinges 20 shipped pair
rear bumper side mounts 15 shipped pair
front bumper mounts 25 shipped pair
horns 10 shipped each or 17 shipped pair
door handles in varying colors available for 35 shipped each
rear door black shiny metal triangle pieces in doors 15 shipped pair
exterior surround black chrome door trim (s4) including rear triangle window and its trim 100 picked up
door strykers, latches 20 shipped for set of 4
door hinge set 45 shipped
door bear claw latch (mounte in the door) 25 shipped each
PS h7 headlight housings 50 shipped (great shape) top 2 tabs broken rest are good, great for oem tab repair kit as the light is in awesome shape
headlight back covers wire spring clip 5 shipped each
headlight back covers 5 shipped each
wiper motor 20 shipped
wiper linkage 30 shipped
wiper and motor linkage 45 shipped
trunk seal 10 shipped
hood seal on core support or firewall (rubber) 10 shipped each
fender side seals rubber 10 shipped pair
rear license plate 20 shipped
rear license plate lights pair 20 shipped
96 euro trunk brand new light bar that you pull on 50 shipped
laser red complete euro trunk lid 200 picked up or 250 shipped
condensor bolt down brackets 10 shipped
radiator dowel pins and grommets 10 shipped
bumper bolts pair 10 shipped or less with other items
axle bolt 6 shipped each or less with other items
HID headlight bulb 15 shipped each
corner bulb holder 10 shipped for pair
corner bulb 5 shipped for pair
tail light bulb holder pair themselves 30 shipped
oem HID ballast and bulb 100 shipped
Interior:
wiper/stalk/turn signal unit 45 shipped
(silver cars)complete s4 black leather interior including: front power and heated seats, rear seats (all three pieces), rear side bolsters, and all 4 door cards 650 picked up or 900 shipped
a4 interior including front manual leatherette seats, rear leatherette seats and rear side bolsters; all in black 100 picked up
Blue cars black leather s4 rear seat set includes lower seat, both upper seats, and rear bolsters 225 shipped or 155 picked up
blue cars door cards (couple of a crack in the speaker grill)- see pics 200 shipped all 4 or 100 picked up
complete black s4 upper half conversion including: headliner, sunroof cover, rear deck cover, a, b ,c pillar covers, homelink visors, visor lights, visor clips, center sunshade, sunroof snap ring, front and rear light clusters, ohh **** handles, 4 rubber/black felt door moldings/seals and wiring harness 350 shipped
black double din s4 center console conversion:center console skin, radio cage, radio, main cc frame, cupholder, fog and esp bittons, hazard button, climate control HVAC unit, ash tray, rear center console with black leather arm rest, rear cup holders, cig lighter assembly, leather 2 piece ebrake covers, rear ash tray, trim caps, and hardware 250 shipped
complete dash with all vents 50 picked up or 100 shipped
complete black s4 seat belt set 45 shipped
clockspring (esp based and non esp based cars) 45 shipped each
dash without vents 30 picked up or 80 shipped
just headliner 40 picked up or 75 shipped
a pillar covers 15 shipped
just black rear seat belts 15 shipped each
gauge cluster 100 shipped
boost gauge 25 shipped
black plastic hazard button surround 35 shipped
9 piece wood trim set 125 shipped
9 piece brush alum trim set with black plastic center console pieces 255 shipped
6 piece brush alum trim set 200 shipped
Pass side airbag 35 shipped
black leather shift boot 15 shipped
Side curtain airbags pair 75 shipped or 45 shipped each
steering wheel (6 speed, no buttons) 55 shipped
steering wheel TIP with airbag black 90 shipped
TIP airbag 50 shipped
TIP steering wheel 50 shipped
brown 6 speed airbag 45 shipped
column top snap on piecve accordian trim cover 15 shipped
accordian trim colum assembly whole unit 25 shipped with top cover
door, trunk, and ignition locks and 3 key system 150 shipped
door trunk and ignition lock and 1 key system 100 shipped
key fob 25 shipped
airbag module 65 shipped
interior carpet (whole thing) 50 picked up or 100 shipped
seat rail covers set of 8 25 shipped
security modules (color boxes on rear window) set for 20 shipped
interior wiring harness 50 picked up or 100 shipped
low pair of kick panels black 30 shipped pair
lower b pilalr covers black 40 shipped
lower dash DS knee bolster 40 shipped
complete glove box 45 shipped
glove box strut 15 shipped
complete HVAC system box with blower motor, heater core, evap core, all motors and servos and flapper valves 90 shipped
dash vents (side ones) 15 shipped each
center dash vet (tripple cluster) 30 shipped
fuse panel cover DS 15 shipped
fuse panel cover PS 10 shipped
lower interior black plastic door sills (inside ones that cover the carpet edges) 55 shipped
relays etc 8 shipped each
headlight/fog light relay box (above glove box) 25 shipped 30 shipped modded for indep fogs
metal support under dash 55 shipped
door and rear deck speakers 40 shipped each or less if buying multiples
rear door arch way black plastic (follows seat line up, curved piece) 10 shipped for pair
airbag modules under carpet in front with yell connector 10 shipped each
headlight range control module under rear seat 15 shipped
ESP control box under rear seat 25 shipped
CD changer 55 shipped
CD bracket 15 shipped or together with changer for 60 shipped
security module under CD changer bracket 15 shipped
bose s4 amp (same for a4 bose system) 40 shipped
interior trunk carpeted sides 15 shipped each or 25 shipped for pair
interior trunk floor carpet 10 picked up or 45 shipped
trunk spare wheel/tire hold down 10 shipped
full set of s4 manuals with cover case 40 shipped
rear plastic trunk cover on back of trunk going the width of it 45 shipped
cubby hole side tray in trunk 8 shipped
carpeted side interior light 6 shipped
dead pedal 8 shipped
complete sunroof assembly with motor and glass 50 picked up or 100 shipped
just sunroof glass 45 shipped
just sunroof motor 25 shipped
just sunroof sliding assembly 15 picked up or 65 shipped
varying other grommets or modules 5-15 shipped each
fuel pump black cover 7 shipped
fuel pump blue in/out cover 10 shipped
fuel fump screw on cover ring 10 shipped
cargo net 35 shipped
rear seat black carpet floor mats (set of 2) 25 shipped
hood latch (hood side) 25 shipped
hood latch (core support side 15 shipped)
hood latch release cable and pull 10 shipped
Suspension and Brakes and wheels/tires:
set of 4 rs4 DTM wheels, center caps, lug nuts, and like new continental DWS tires 800 picked up or 1000 shipped
1 s4 wheel with tire (bad) 100 shipped
AT italia s4 look alike reps with ok tires about 40 percent life on them 400 picked up or 500 shipped set of 4
set of 20 lug nuts (oem ball seat) 25 shipped
set of 20 cone seat lug nuts (have both extended and stock size) 25 shipped each set
H&R coilovers 800 shipped
abs module and pump assembly (whole thing) 100 shipped
front s4 brakes includes calipers, carriers, pads, lines and rotors (rotors are like new and pads are like new) 275 shipped
front s4 uprights 200 shipped with good hubs and bearings
rear uprights with good hubs and bearings 150 shipped pair or (75 shipped each)
rear upright with no hub or bearing 45 shipped each
power steering rack with inner and outer tie rod ends 150 shipped
Power steering rack with no outer tie rod ends 125 shipped
Front control arm set 75 shipped or 15 shipped each
rear upper shock hats with arms 45 shipped pair or 25 shipped each
rear upper shock arms only pair 20 shipped
rear lower control arm 20 shipped each
rear subframe 50 picked up or 100 shipped
front subframe 50 picked up or 100 shipped
headlight level adjusters on control arms 25 shipped each (1 in front and 1 in rear)
front and rear sway bar set with bars, end links, bushings, brackets, and hardware 85 shipped
just rear sway bar set with bar bushings, brackets, end links, and hardware 50 shipped
rear diff carrier bracket with stock bushings 25 shipped
rear diff mount stock 25 shipped
rear diff mount front mounting bracket 15 shipped
upper triangular hats on front struts 10 shipped each or 15 shipped pair
rear tie rods 25 shipped pair
stock tranny mounts 10 shipped each
brake master cyliner 30 shipped
brake booster 30 shipped
Brake booster and master cylinder combo 55 shipped
brake lines from master to abs 15 shipped
Extras:
Please contact me for wiring snippets and small pieces of hardware or bolts or trim or lines
I have quite a bit of that available including an entire cars worth of hardware as well
Examples -
headlight wiring, headlight back caps, trans bolts, axle and driveshaft bolts, fog light wiring, cluster wiring, 6 speed conversion wiring, headlight dowel mounts, hinges, moldings, stereo wiring, bolts, screws, covers, CLP wiring, etc etc.
SOLD
shifter linkage SOLD
044 fuel pump with basket and hardware SOLD
Silver s4 lower door moldings SOLD
Santorin Blue sideskirt set SOLD
DS rear santorin door shell SOLD
torque converter SOLD
stereo SOLD
Santorin cars front seats sold (silvers avail)
PS santorin front fender SOLD
Silver PS front fender SOLD
radiator SOLD
Core Support SOLD
Santorin blue hood SOLD
Santorin cars lock set SOLD
Santorin front bumper SOLD
silver rs4 front bumper SOLD
central locking pump SOLD
rear s4 brake set SOLD
Pictures:
Link to phot album so you can just copy and paste or click to see all pics:
http://s42.photobucket.com/albums/e3...view=slideshow
y pipe 50 shipped
AC dryer 15 shipped
cam plug 7 shipped
PS tank 10 shipped
ABS tank 10 shipped
Exterior:
gas cap 10 shipped
Interior:
key fob 25 shipped
Extras:
Examples -
SOLD
stereo SOLD
radiator SOLD
Core Support SOLD
Pictures:
pzp107
30
03-25-2013 01:20 AM
pzp107
03-25-2013 01:18 AM
pzp107
09-19-2012 01:45 PM
pzp107
08-30-2012 03:31 PM
audiway
08-11-2011 11:16 AM
