AudiForums.com
-   Wheels and Tires (https://www.audiforums.com/forum/wheels-tires-74/)
-   -   Winter Wheels/Tires (https://www.audiforums.com/forum/wheels-tires-74/winter-wheels-tires-201264/)
zoewagner 10-22-2013 10:00 AM
Winter Wheels/Tires
I have a 2002 TT quattro and was wondering if wheels with winter tires from a 2011 TTS would fit. They are slightly used and for a good price. Just want to see if they would fit my car.
AWDaholic 11-01-2013 01:03 AM
The wheels will fit, yes. The factory bolt-circle diameter and offset will almost assuredly be the same.
The question is: Are you keeping the old tires that come with those winter wheels? How old are they (the tires)? How much tread left? Are you getting them professionally balanced, prior to mounting them?
OK, that was 4 questions, but they do need to be asked/answered.
zoewagner 11-01-2013 10:00 AM
AWDaholic, thanks for the reply. To answer your questions, yes keeping tires as they were used 1 winter and look like new (less than 2k mi), and were balanced when he bought them new, so I would assume they are ok. He is moving to FL and will not be needing anymore, hence the availability of them. I was told from someone else that they would only fit if I use adapters as the pattern is different between the two. Either way, I think I will get them.
Thanks!
Zoe
