Winter Wheels/Tires
The wheels will fit, yes. The factory bolt-circle diameter and offset will almost assuredly be the same.
The question is: Are you keeping the old tires that come with those winter wheels? How old are they (the tires)? How much tread left? Are you getting them professionally balanced, prior to mounting them?
OK, that was 4 questions, but they do need to be asked/answered.
AWDaholic, thanks for the reply. To answer your questions, yes keeping tires as they were used 1 winter and look like new (less than 2k mi), and were balanced when he bought them new, so I would assume they are ok. He is moving to FL and will not be needing anymore, hence the availability of them. I was told from someone else that they would only fit if I use adapters as the pattern is different between the two. Either way, I think I will get them.
Thanks!
Zoe
Thanks!
Zoe
wpg2.0T
10-29-2011 01:55 PM
ET3 Callahan
11-07-2007 11:44 PM
