1993 Audi 100cs Transmission switching gears at LOW RPM.
Old 07-26-2016, 12:30 PM
DarDarBinks's Avatar
Default 1993 Audi 100cs Transmission switching gears at LOW RPM.
Hey everyone! i need some insight into a problem i am having.
About 4 months ago my Audi 1993 audi 100cs automatic transmission started switching gears early at lower RPMs than normal.
it will change from gear 1 to gear 2 between 2500 to 2800 rpm (Strong)
but from gear 2 to 3 and 4 its switching at 1600 - 1800 rpm (Weak)
so as you can imaging it can be a struggle on the freeway and a nightmare on hills. i have to floor it to compensate the different, but it struggles.
Currently i have to drive it like a manual. driving at lower gears and shift up when the RPM is just right for the power needed.
the car has about 270k miles on it and had a transmission flush and solenoid check about 40k miles ago. All shifting up and down is smooth and fluids have always been nominal at all times.
Could this be a Transmission control module (TCM) problem?
any tips will be helpful. THANKS!
thedon28
07-16-2014 01:20 PM
AUDI1993
07-23-2012 11:50 AM
peter121
05-20-2009 06:11 PM
eurostyle88
04-09-2007 02:13 AM
yatem
03-09-2005 07:19 PM
Quick Reply: 1993 Audi 100cs Transmission switching gears at LOW RPM.
