A4 Turn Signal Relay
Old 07-20-2004, 12:40 AM
eckopass's Avatar
Default A4 Turn Signal Relay
Hey, I have this '00 A4 and the turn signal is acting weird. It flashes once then doesn't flash any more than that. The fuse checks out fine, the hazard relay is flashing fine, but the turnsignal (r and l) don't flash.
I *think* I have located the relays (behind the fuse block), but don't know which one is the turn signal relay.
I'm totally guessing that the relay is bad, since the flasher for the hazards is still working, I'm thinking relay.
Any suggestions or instructions from the A4 gurus?
Thanks!
Jon
EDIT: Doh! I put this in the A3 forum instead of the A4. I s'pose you A3 gurus will probably know too.
Old 07-24-2004, 06:07 PM
Default RE: A4 Turn Signal Relay
I have an '02 A4...thought the turn signal bulb was out, replaced bulb same problem....hazard lights work... it may be your hazard light relay which I read was located behind the hazard button (not sure if your relays are behind the fuse block try behind the hazard button)
Old 07-25-2004, 11:25 PM
ImolaS4's Avatar
Welcome to the forum eckopass! And you too, audi911.
Have you sorted this out yet?
wesk11
06-06-2017 10:11 PM
choppedelight
01-18-2017 10:21 PM
cmarin
07-10-2014 10:10 AM
Mojo3
04-17-2012 12:40 AM
tommy
06-18-2007 05:54 PM
Quick Reply: A4 Turn Signal Relay
