Sponsored by:
Sponsored by:
Front Suspension Noises?
Old 02-06-2007, 04:19 PM
Euro68's Avatar
Default Front Suspension Noises?
My front end has recently started making some funny noises, every time I turn the wheel I hear a squeaking noise, but I think thats just a squeaky ball joint that needs to be replaced. But, when ever i turn sharply at low speeds (under 20mph) you can hear a clicking noise from outside the car. A friend said it might be a 4 wheel drive hub, but does the quattro system even have hubs like big 4x4 trucks? Thanks for any help.
Edit: this is a 98 a4 quattro with 65k
Old 02-06-2007, 04:26 PM
nickellis14's Avatar
Default RE: Front Suspension Noises?
the squeaking may be a bad belt that goes to your power steering pump. you shouldn't need ball joints at 65k, though its not that difficult to find out. take your wheel off and look. as far as the clicking, could be the wheel bearing. not sure about the drive hub. if the ball joint is gone, that might explain the clicking too, but i seriously doubt it is unless you take this thing off-roading.
Old 02-06-2007, 04:38 PM
acetrebo's Avatar
The noise is common for worn control arms. I fixed mine by spraying the heck out of them with pb-blaster and wd-40. And driving the hell out of the car!
The other sounds like a bad wheel bearing.
http://www.audiworld.com/tech/wheel44.shtml
Old 02-06-2007, 04:51 PM
Dj Spiel's Avatar
power steering,outer tierods,worn control arms...
can be any of above.
Old 02-06-2007, 04:59 PM
swift_A4's Avatar
+1 ^
Old 02-06-2007, 05:01 PM
akielb's Avatar
+1 on control arms - take a look at the sway bar link 1st I have a 98.5 and I'm changing that this weekend.
clicking sounds like the CV most likely
Old 04-23-2007, 03:06 PM
sasquatch's Avatar
Clicking while turning is almost always the outer CV Joint. If you DIY, replace the whole axle on that side - it's cheaper in the long run - and your parts store should give you a refund for the core.
Old 04-23-2007, 03:37 PM
Black_97 A4's Avatar
I had that same problem on my 97 A4 and it was the lower control arm...might be what you need..but it was kind of costly, so i'd check before replacing.
flew66
04-26-2010 11:37 AM
alexrussell1988
02-22-2008 01:31 PM
akielb
05-16-2007 10:14 AM
MingDriver
09-15-2006 12:10 AM
jayson161
06-12-2006 08:02 PM
Quick Reply: Front Suspension Noises?
