HOw to install new radiator??
RE: HOw to install new radiator??
I have a B6 model and this is my first time doing it so I am gonna need some play by play instructions please. I never had to do this. TYhe whole reason y I got the new radiator was because I saw steam coming out the passenger side of the radiator.
A b6 guy said it was similar to the b5 and linked a b5 write up. To get to the timing belt, you have to get past the radiator so you'll be looking at parts of a timing belt job write up.
http://www.audiworld.com/tech/eng.html
Between this and cincy's diagram you should be able to pull it off. My biggest tip would be when filling up the radiator fluids, mix the water and pink before you add it. That way you'll have the right mixture even if it fills up before your done filling it... if you know what i mean.
neomaxddr
03-28-2009 07:16 PM
cvacc411
01-29-2009 04:58 PM
