Sponsored by:
Sponsored by:
HOw to install new radiator??
Old 01-09-2008, 03:30 PM
Supaant06's Avatar
Default HOw to install new radiator??
I am in dire need of some assistance regarding an install of my new radiator that I had just purchased. Its my first time and I dont wanna screw anything up. PLEASE HELP!!!!
Old 01-09-2008, 03:40 PM
cincyTT's Avatar
I'm make believe
Default RE: HOw to install new radiator??
Why do you have a new one, the old one have a hole in it? Basically drain the coolent, pull the hoses, and then unbolt it from the frame. Shouldnt be to hard.
Old 01-09-2008, 04:02 PM
duburban's Avatar
Chill man, its easy. Take off your bumper. 2 bolts on front. 1 screw in each wheel well. From there its cake, look at a timing belt DIY on audiworld.
Old 01-09-2008, 04:30 PM
Supaant06's Avatar
I have a B6 model and this is my first time doing it so I am gonna need some play by play instructions please. I never had to do this. TYhe whole reason y I got the new radiator was because I saw steam coming out the passenger side of the radiator.
Old 01-09-2008, 04:49 PM
cincyTT's Avatar
I'm make believe
Old 01-09-2008, 06:03 PM
Trey25's Avatar
I dunno but on the b5 it's not a simple 20 minute job. It took me 2hrs in the freezing cold. The hardest part was removing the oil cooler lines, PITFA.
Old 01-09-2008, 06:33 PM
Supaant06's Avatar
thanks man! one more thing... do these wonderful pics have written instructions with them???
Old 01-09-2008, 06:51 PM
cincyTT's Avatar
I'm make believe
no, just names and part numbers.
Old 01-09-2008, 08:23 PM
duburban's Avatar
A b6 guy said it was similar to the b5 and linked a b5 write up. To get to the timing belt, you have to get past the radiator so you'll be looking at parts of a timing belt job write up.
http://www.audiworld.com/tech/eng.html
Between this and cincy's diagram you should be able to pull it off. My biggest tip would be when filling up the radiator fluids, mix the water and pink before you add it. That way you'll have the right mixture even if it fills up before your done filling it... if you know what i mean.
PfcRCosta
05-23-2009 01:23 AM
neomaxddr
03-28-2009 07:16 PM
cvacc411
01-29-2009 04:58 PM
oc_audica
08-20-2008 06:16 PM
auditamer
10-06-2007 12:46 PM
Quick Reply: HOw to install new radiator??
