Sponsored by:
Sponsored by:
READ THIS IF YOU HAVE A CHECK ENGINE LIGHT!
Old 01-18-2012, 12:34 AM
MarrakeshRed's Avatar
where are the replies?
  #22
Old 01-18-2012, 08:35 PM
Originally Posted by njscardino
Ran into a CEL yesterday. Threw a code for P0411 I believe, a blockage in the secondary air pump unit, or something along those lines. Turned out it was the vacuum line going to the combination valve. The line was too short and it was pinching somewhere, causing a blockage. So if any of you run into this and you are able to test all the other components, this may be your cause ....
I've been receiving this same code from a CEL for the past 2 years. I thought it may be just a faulty secondary Air injection system however lately I have been hearing it run after starting the engine up on cold days only to still have the P0411 keep coming back after I erase the CEL codes...so this vacuum line that goes to the combination valve..well I cant seem to find it..could you please post up some pics or a better description of where it may be??? Thank you
  #23
Old 03-08-2012, 01:17 PM
Bayleybeee's Avatar
Cool 3 different codes :(
My A4 has had multiple ongoing problems. I believe my turbo may be malfunctioning or I have a major valve/vacuum leak- I'm not sure. Here are the codes:
P0507-Idle air control system RPM higher than expected
P0722-Output speed sensor circuit no signal
P0171-system too lean-bank 1
ANYONE, PLEASE HELP ME!!!!!
-xoxo
  #24
Old 03-24-2012, 05:26 AM
trish44's Avatar
Default usautoparts
ShowMeTheParts is an Open Platform for Sharing usautoparts Automotive Aftermarket content
  #25
Old 09-10-2012, 10:14 PM
Tyler b5's Avatar
Thats your abs sensor
  #26
Old 01-17-2013, 12:07 PM
Emonahan's Avatar
Originally Posted by SincereOne12
I would not suggest driving your car too far if you're check engine light is flashing because of a misfire. Your fuel will eat the hell out of your catalytic converter and your 100 ignition coil and whatever else you spend on coils will end up running you $4000 on a new cat. So watch it.
Well it shouldn't be a problem if he lives close to the auto parts store. It won't kill the car especially if he has been using it daily
  #27
Old 04-14-2013, 02:15 PM
Stevendurh's Avatar
Got a call from my wife who told me that the CEL (which has been on for two months) started flashing and the car started running "funny" (she's not much of a car person). She immediately shut it off after pulling back into the garage. After reading a few of these posts, I have a couple of questions. Before I go too much farther, the car is a 2007 a-4 cabriolet Conv.
1. I recently drove off from a gas station with my gas cap off, and read here that that's bad. Assuming that no one tampered with my car, why would this cause the CEL to come on?
2. I have an extended warranty, and if its something serious like coils or the cat converter, are these things usually covered?
3. When they plug the car in and read the fault code, does it tell them how long the CEL has been on. I'm wondering if driving it so long with the light on will void the warranty?
Thanks in advance!
  #28
Old 07-15-2013, 07:26 PM
jpjmustang's Avatar
Default Vag - obdii
Whats the difference between a OBDII and A VAG
Is it worth getting a VAG?
  #29
Old 10-27-2013, 12:27 PM
autoexpert's Avatar
  #30
Old 10-04-2014, 05:43 AM
Closer's Avatar
This thread is about as useful as the cel telling you anything besides it's on.
Quick Reply: READ THIS IF YOU HAVE A CHECK ENGINE LIGHT!
