Sponsored by:
Sponsored by:
04 Audi A6 3.0 TDI Quattro S Line - Engine stalling when idle
Old 10-21-2014, 11:18 AM
gerrydrumm's Avatar
Default 04 Audi A6 3.0 TDI Quattro S Line - Engine stalling when idle
Hello, I have recently purchased an 04 Audi A6 3.0 TDI Quattro S Line and have started to experience problems that led me to this site. When the car is running idle whether in D or P, the engine has started to stall. When the car is driving it is going 100%, however when stopped at junctions it is likely to stall. I put the computer on it to get the following code;
17471 Fuel Pressure Regulation: Control Range Not Reached: P1063
I was quoted £240 for the necessary sensor but was told this may not even solve the problem. Has anyone encountered a similar problem and how was it solved? This is my first time using the site so thanks for any help.
Old 02-25-2015, 03:00 PM
tdi4ever's Avatar
Default hello
exactly the same thing is happening to my 2005 3.0 tdi quattro bmk engine code. i get the same erorr code 17471. the mechanic told me to replace the fuel pressure regulator but may not solve the problem. how did u solve it. thank you
Old 02-27-2015, 04:15 PM
gerrydrumm's Avatar
I was told it could be bad diesel. Before replacing any parts which were all going to cost a fortune I ended up driving all the diesel out of the car and put £10s worth in again and did this a few times. This seemed to work as it hasn't stalled again since. The fuel sensors must be very sensitive.
lewis_Duffield
03-02-2015 03:31 AM
lozzyho
11-26-2012 03:02 AM
AD2
02-01-2010 09:24 PM
menio
05-20-2008 12:39 PM
corradophil
11-27-2007 05:41 AM
Quick Reply: 04 Audi A6 3.0 TDI Quattro S Line - Engine stalling when idle
