Sponsored by:
Sponsored by:
2000 A6 low brake warning always on
Old 04-19-2015, 07:45 PM
Hondadogie's Avatar
Default 2000 A6 low brake warning always on
How do I diagnose the system for the brake sensors? When pads are ok, should the sensor be an open or closed circuit? So I can tell if it's pads or the circuit.
Old 04-20-2015, 12:27 PM
ManyAudis's Avatar
The circuit is closed when the pads are OK. When the pads wear they eventually break the wire which runs through the pad opening he circuit causing the warning light to come on. You should pull each wheel and unplug the pad connectors and check continuity. If the pads are OK then build yourself a cheater and short the two pins on the car side of the connector, one side at a time and see if the light goes out, make sure you clean the connector contacts before you do this test. The problem is typically a broken wire in the pad or a corroded connector.
ElDrago
02-23-2012 04:54 PM
rodick
09-08-2008 05:48 PM
manik_ee
07-30-2007 04:46 PM
NuYorka103185
01-23-2007 03:25 PM
Quick Reply: 2000 A6 low brake warning always on
