Hand Brake Not Engaging & Brake Pad Warning Light
Old Sep 8, 2008 | 05:48 PM
rodick's Avatar
Default Hand Brake Not Engaging & Brake Pad Warning Light
My brake pad warning light has been on for a few weeks. I peeked at the outer pads on each wheel, and all have plenty of life left, as they should, since none are much older than a year. I haven't crawled under to check the inside pads yet. I suppose it's possible that a sticking caliper could be causing uneven wear on the inside, triggering the warning light....though that's just one possibility that I haven't even bothered to confirm yet.
However, about a week ago, I started noticing slack in the hand brake. When I engage it, there's an inch or two where I feel no resistance before it catches. And even when it's fully engaged, it won't hold the car in place on a moderate incline.
So my question is, are these problems likely related, or merely a coincidence? Any thoughts/suggestions would be greatly appreciated.
And my follow-up questions: if my brake pads are NOT significantly worn, what would be triggering the warning light? And, is the hand brake easily adjusted from the console?
Thanks in advance,
Peter
steveleroy
May 27, 2010 08:51 PM
jerrod22
Dec 5, 2007 09:22 AM
mikeysentra
Jan 10, 2007 05:37 PM
AudiA4life
Jun 1, 2006 03:07 AM
