2001 a6 avant alarm trouble
If yes, and it's only a problem with the keyfob not working, then it likely just needs to be resync'd.
If your remote is the original one that was already programmed to the car:
Lock door manually
Press lock button on keyfob
Unlock door manually
press unlock button on keyfob
If not, then you will need a second key, doesn't have to be a remote:
Put one key in the ignition and turn the car to ON/Accessory position (do not start)
Take the keyfob you're trying to program and lock the door manually
press lock button on keyfob
unlock door manually
Turn car off and remove key from the ignition and test the remote
