Sponsored by:
Sponsored by:
2001 a6 avant alarm trouble
Old 09-07-2013, 04:35 PM
gray_hawk99's Avatar
Unhappy 2001 a6 avant alarm trouble
I recently bought a 2001 a6 avant 2.8l and my alarm does not activate when I try to set it no lights no beep nothing any suggestions?
Old 09-08-2013, 02:14 AM
OGBULLYLOCDAWG's Avatar
Does it at least activate when you lock the car using the key in the door? (horn should beep and the red LED on the door starts blinking).
If yes, and it's only a problem with the keyfob not working, then it likely just needs to be resync'd.
If your remote is the original one that was already programmed to the car:
Lock door manually
Press lock button on keyfob
Unlock door manually
press unlock button on keyfob
If not, then you will need a second key, doesn't have to be a remote:
Put one key in the ignition and turn the car to ON/Accessory position (do not start)
Take the keyfob you're trying to program and lock the door manually
press lock button on keyfob
unlock door manually
Turn car off and remove key from the ignition and test the remote
Old 09-08-2013, 09:34 AM
The alarm doesn't set even with just the I checked the keyfob and that works the alarm just doesn't set its doesn't beep nor does the led come on and flash
Old 09-09-2013, 05:06 PM
ex56TT's Avatar
Banned
check wiring harness in doors, common place for wires to break and short causing all sorts of issues with alarm
Old 09-10-2013, 07:35 AM
Sweet thanks I'll check that out I knew my vw but am clueless with the audi lol
Old 11-19-2013, 04:54 PM
ex56TT's Avatar
Banned
same crappy wiring harness, made in mexico
tb30570
06-19-2012 11:16 AM
dannnn
05-12-2009 09:10 AM
dannnn
05-12-2009 06:07 AM
smoovmusicdj
11-27-2007 12:26 AM
eagle9876
11-15-2006 09:42 AM
Quick Reply: 2001 a6 avant alarm trouble
