Sponsored by:
Sponsored by:
2003 A6 V6 - fault code P0441 / 16825 - purge valve replace (pics)
Old 12-28-2012, 07:43 PM
crisTSM's Avatar
Default 2003 A6 V6 - fault code P0441 / 16825 - purge valve replace (pics)
2003 A6 V6 automatic (no turbo, no quattro)
71,700 miles
Check engine light on.
Car runs and drives o.k. and fuel consumption normal.
The only things which does not look normal are:
- idling about 50 RPM higher
- when coming to stop, still in drive, RPMs go down a little and then idling about 50 RPM higher then normal.
Checking with ross-tech cable and software shows:
16825 - EVAP emission control sys
P0441-002 - incorrect flow - intermittent - MIL ON
See possible causes and solutions here:
16825/P0441/001089 - Ross-Tech Wiki
You can clean the purge valve as indicated by user vrso2 on this forum:
https://www.audiforums.com/forum/aud...solved-132508/
In case you decide to replace purge valve see pics:
remove the cover by lifting up:
2003 A6 V6 - fault code P0441 / 16825 - purge valve replace (pics)-simg_a.jpg
2003 A6 V6 - fault code P0441 / 16825 - purge valve replace (pics)-simg_b.jpg
disassemble the electric connector and 2 hose clamps and remove the purge valve:
2003 A6 V6 - fault code P0441 / 16825 - purge valve replace (pics)-simg_c.jpg
Assemble in reverse order.
I purchased purge valve from Auto Parts Warehouse for $60; part was aftermarket replacement, identical with OE, made in East Europe.
Old 01-06-2013, 01:03 PM
johnlwaugh's Avatar
Default Engine Light after refueling. Any Idea's?
Thanks for the in site. I have a 2006 A8L 4.2 that gives me an Engine Light every time I refuel.
The purge valve has been replaced by the previous owner, so I was told.
Old 01-08-2013, 01:55 PM
crisTSM's Avatar
Check engine light remains on or is off after a while ?
If it stays on, you have to check the fault code to be able to try to track what it is wrong.
Some Auto Zone shops do this for free.
Old 01-10-2013, 09:02 AM
johnlwaugh's Avatar
Thanks, I am waiting for my VAG diagnostics to arrive to do just that. The light stays on. I have had my mechanic reset it once. That is when I found out what was causing the engine light. I may have a leak. Thanks again.
tophand576
02-02-2019 06:33 PM
vrso2
01-16-2018 08:42 PM
guitarliketom
12-13-2008 01:23 PM
jeffwantsaaudi
12-20-2007 06:49 PM
Quick Reply: 2003 A6 V6 - fault code P0441 / 16825 - purge valve replace (pics)
