Sponsored by:
Sponsored by:
Audi 4.2 Oil Pan 28 hour labor????
Old 09-10-2012, 07:37 PM
masurati's Avatar
Default Audi 4.2 Oil Pan 28 hour labor????
I have 08 Audi 4.2 fsi. One mechanic lied to me that my oil pan was leaking and he wanted to charge 28 hour for labor. I took it to other mechanic and we both saw there was no leak.
I checked with other mechanics and they really charge 28 hours to replace the oil pan and gasket on those engines in an a6.
Can anybody tell me why does it take this long to change a oil pan gasket?
I looked at the oil pan and there is some pipe covering it but i dont think removing the pipe woul take that long.
Any ideas???
Old 12-18-2013, 03:34 PM
crosbo's Avatar
Is there a better way...shorter route...less expensive option on how to proceed to change the oil pan gasket on the 4.2?
Old 12-18-2013, 06:59 PM
Nebuchadnezzar's Avatar
Any ideas???
I'm not terribly familiar with the 4.2 setup, but I believe the entire subframe must be dropped in order for the pan to be removed. Can anyone else confirm this?
28 hours though? That's a lot of time for a somewhat experienced mechanic to tackle the job.
Old 12-18-2013, 07:40 PM
sgt_smoke's Avatar
My 01 with 4.2 would be really easy to change. Probably take me 1-2 hour. 30 min finding my tools and drink two beers
Old 12-19-2013, 07:13 AM
M5S5's Avatar
Tech Certified
There are 2 oil pan gaskets on these engines a upper & lower. Depending on what vehicle the engine is in (you did not mention what model) , a upper gasket would be between 6 & 15 hours.
Stay away from the shop that quoted you 28 hours.
Old 05-24-2014, 01:33 PM
Andrewn13's Avatar
Default Lower oil pan
I got quoted 3 hours after the 28hr book quote and it's a silicon replacement not a gasket Audi charges 70$ish for a diagnostic. I'll do a DIY when I am done.
Cheers!
Old 03-15-2018, 04:04 PM
Sukidookie808's Avatar
Default Did you have any success?
Hi I have an 2008 Audi q7 4.2 and I just wanted to know if you had any success of removing the oil pan and if so what were the steps taken. Any help would be much appreciated.
slimmj0k3r
06-03-2013 09:02 PM
Audi Forums Editor
01-28-2013 05:08 PM
lenk58
Dealerships
26
10-29-2012 12:20 PM
kidislegit
04-07-2008 09:26 AM
shift
02-01-2006 02:22 AM
Quick Reply: Audi 4.2 Oil Pan 28 hour labor????
