Sponsored by:
Sponsored by:
ECM replacement
Old 01-02-2014, 11:52 AM
dshybull's Avatar
Default ECM replacement
Is it true that you need to computer mate the ECM to the system for proper operation? There is a post on here that says he bought a used ECM and just plugged it in with no issues
(https://www.audiforums.com/forum/aud...acement-62997/) Is this TRUE because im having similar issues. I have no power to the coils or to the ignition module. Have replaced the crankshaft sensor and tested all fuses which leads me to believe that it is all coming down to the ECM. Have not check the cam sensor yet though. But i will be doing that as soon as i find the check list for that.
Old 01-02-2014, 11:55 AM
M5S5's Avatar
Tech Certified
What year & model car do you have? it would be much easier to help with that info. & for the most part , the ecm will have to be either coded or programmed , plug & play ended in the mid 90'S.
Old 01-02-2014, 12:04 PM
dshybull's Avatar
1997 A6 Quattro 2.8 V6 C4 chassis i think
Old 01-02-2014, 12:06 PM
M5S5's Avatar
Tech Certified
would probably need to be coded but a good used one should work. Might want to check wiring diagrams & see what powers the coils & module.
Old 01-02-2014, 12:09 PM
dshybull's Avatar
Have you read this link? How can that be? https://www.audiforums.com/forum/aud...acement-62997/
Old 01-02-2014, 05:21 PM
ManyAudis's Avatar
I am pretty sure for the C4 chassis you can just swap the ECM if the engine and tranny are the same. The newer cars have an issue with component protection coding but that was not implemented on the C4.
Old 01-03-2014, 03:09 PM
dshybull's Avatar
Well i bought a used ECM on ebay and im going to give it a shot to see if it actually does work. Will let you know if it does. thx
Old 01-15-2014, 09:52 AM
dshybull's Avatar
Default Car is fixed
Fixed car but never tried the ECM swap
mokey40
B7 Models
11-28-2014 12:42 PM
mtnxtreme
Audi Q7
12-16-2013 01:11 PM
matthayzon89
07-31-2013 10:51 PM
hankeester
06-24-2009 12:10 PM
Quick Reply: ECM replacement
