Sponsored by:
Sponsored by:
master window switch
Old 07-20-2008, 05:14 PM
jj2345's Avatar
Default master window switch
how do you remove the master window switch on the driverfront without breaking anything on the c5,the windows in the back seems not to work when someone in the rear tries to bring them down,yet i could up front with no problems.can someone help me out
Old 07-20-2008, 05:38 PM
alexfunari's Avatar
Default RE: master window switch
easy fix, just buy a new one www.autopartswarehouse.com item number "W0133-1735609" its only 33.45. Cheapest I've found online.
Old 07-20-2008, 05:39 PM
alexfunari's Avatar
p.s. this is a common problem, using the search would have shown you a solution.
Old 07-20-2008, 05:49 PM
jj2345's Avatar
thanks alot man
Old 07-20-2008, 05:56 PM
alexfunari's Avatar
forget about what i told you, buy it from ebay right now. here is the link. its an OEM replacement http://cgi.ebay.com/ebaymotors/AUDI-...spagenameZWDVW
Old 07-20-2008, 06:03 PM
jj2345's Avatar
wow!! 4 bucks you cant beat that
Old 07-21-2008, 12:44 AM
a6hcw's Avatar
Too bad the shipping and insurance chargesare so high for the ebay switch! The total cost would be $30.99, not $3.99.
Old 07-21-2008, 04:03 PM
Rhino85's Avatar
SoCal Crew Member
Just quickly you didn't accidently hit the window lock did you?
Old 07-21-2008, 04:32 PM
massboykie's Avatar
Member
[quote]ORIGINAL: jj2345 how do you remove the master window switch on the driverfront without breaking anything on the c5.../quote]
Hey JJ
This should do it....
http://www.vaglinks.com/Docs/Audi/C5...Front_Door.pdf
Cheers
Massboykie
Old 07-21-2008, 09:14 PM
jgurland's Avatar
It's pretty easy to remove the switch. If I remember correctly, it's just a pressure fit. If you look on the underside of the arm rest there's a hole. Gently (but firmly) push a Philips head screwdriver into the hole and the whole switch assembly will pop upward, out of the arm rest.
Good luck.
Quick Reply: master window switch
