master window switch
how do you remove the master window switch on the driverfront without breaking anything on the c5,the windows in the back seems not to work when someone in the rear tries to bring them down,yet i could up front with no problems.can someone help me out
RE: master window switch
easy fix, just buy a new one www.autopartswarehouse.com item number "W0133-1735609" its only 33.45. Cheapest I've found online.
p.s. this is a common problem, using the search would have shown you a solution.
thanks alot man
forget about what i told you, buy it from ebay right now. here is the link. its an OEM replacement http://cgi.ebay.com/ebaymotors/AUDI-...spagenameZWDVW
wow!! 4 bucks you cant beat that
Too bad the shipping and insurance chargesare so high for the ebay switch! The total cost would be $30.99, not $3.99.
Just quickly you didn't accidently hit the window lock did you?
[quote]ORIGINAL: jj2345 how do you remove the master window switch on the driverfront without breaking anything on the c5.../quote]
Hey JJ This should do it.... http://www.vaglinks.com/Docs/Audi/C5...Front_Door.pdf Cheers Massboykie |
It's pretty easy to remove the switch. If I remember correctly, it's just a pressure fit. If you look on the underside of the arm rest there's a hole. Gently (but firmly) push a Philips head screwdriver into the hole and the whole switch assembly will pop upward, out of the arm rest.
Good luck. |
