Sponsored by:
Sponsored by:
My Timing belt broke.....
Old 03-06-2013, 01:20 PM
Brad_31558's Avatar
Default My Timing belt broke.....
I just replaced my belt now here's what I did. The problem is a 2003 A6 2.7t with 108,000 miles on her.
I replaced the TB pulley's and the belt. When the belt broke the car was at idle and there was no strange noises when it happend it just shut off.
I made sure the cams were in the correct position, and the engine was at TDC. I replaced the parts as indicated above.
I rotated the engine with a wrench a few times everything sounded great. no wierd noises, so I tried starting it up, everything sounded normal with the exception of it not starting. IT WILL NOT START NOW!!! but it turns over great.
I made sure all connections are hooked up the way they were before I started.
What am I missing? I have to have my car back on the road, because my wife has my other car going to and from college.
Old 03-06-2013, 06:40 PM
TwinTurboC5's Avatar
I'm Confused....Did your belt break first and then you performed the TB job or did you peform the TB job and then had the belt break afterwards?
Old 03-08-2013, 08:38 AM
Brad_31558's Avatar
The belt broke (while the engine was at idle) due to the idler rollers failing. I then replaced the belt and rollers. It turns over fine, it has fire, and fuel, the cams and crank alignment are right on the mark.
Crowss
03-28-2012 09:35 AM
fruitcakesa
12-21-2011 09:31 PM
vtraudt
04-01-2011 09:40 AM
hurricane860
12-08-2008 07:01 PM
DomsA4
06-09-2008 11:14 PM
Quick Reply: My Timing belt broke.....
