Sponsored by:
Sponsored by:
p0014 and P0025
Old 03-07-2013, 09:40 AM
mtizzle981's Avatar
Default p0014 and P0025
2004 A6 3.0 Quattro
I just did timing belt, water pump and all pulleys AND had both heads reconditioned with a few new valves, etc. Used correct timing tools and replaced all four cam gear bolts. Also dropped oil pan, cleaned pump, pick up and removed sludge from bottom of pan. Also replaced oil pump chain guide/tensioner. Car started perfect. One lifter was knocking but stopped after a few minutes. Drove car and it was great. Very responsive. After 20 miles or so, red oil light came on. Immediately pulled over and checked oil. It was low so I added a quart. Started car. Light was gone. Drove 3 miles and light came back on. Oil level ok. No excessive noise in top end. Drove home (2 miles) and let it sit in garage over night. Started this morning perfectly, no lifter noise. No leaks. Drove 5 miles to Auto Zone and had them pull codes. Came up with P0014 and P0025. No idea where to start troubleshooting. Any help would is desperately appreciated.
Old 03-07-2013, 09:07 PM
TwinTurboC5's Avatar
Did the folks at Autozone give you any information on the meaning of the trouble codes??? We can't help you given only the generic OBD Codes....they each have some meaning.
MHCRRA1
04-15-2014 01:55 PM
SilverBullet?
06-25-2012 08:13 PM
Quick Reply: p0014 and P0025
