Sponsored by:
Sponsored by:
Pedal goes to floor???
Old 06-19-2013, 03:43 PM
mcmopar's Avatar
Default Pedal goes to floor???
2001 A6 4.2 brake pedal goes to the floor. It stops the car, but goes to the floor. If you pump it a few times it builds pressure. The master cylinder is full of fluid, no leaks that I can find. Is bleeding them going to do anything? I have searched and not found to much about this, anything from anyone will help.
Old 06-19-2013, 08:06 PM
Jeffla's Avatar
try bleeding the brakes as you suspected.
Old 06-20-2013, 08:49 PM
mcmopar's Avatar
Has anyone else had this help. I have never had a problem like this go away with bleeding. I will try this just in case it does work. Do you bleed them the same as any car furthest away to closest.
Mkacz373
02-15-2014 09:54 PM
audi_tt_4u
01-21-2011 09:42 PM
dusted72
11-21-2010 08:57 AM
fabianandres
03-08-2010 02:25 PM
rgall
06-17-2008 01:45 PM
Quick Reply: Pedal goes to floor???
