Sponsored by:
Sponsored by:
water in passenger footwell, help!!!!!!!!!
Old 10-08-2009, 09:41 AM
NT70's Avatar
Default water in passenger footwell, help!!!!!!!!!
any ideas, done so far.
1, pollen filter
2. regass of air con
3. lagged air con pipes
Old 10-08-2009, 11:05 AM
Siricospeed's Avatar
Default passenger footwell water
On mine, it was the a/c drain. Remove lower dash cover and blow out drain on right hand side of HVAC box above trans tunnel.
I am sorry I do not understand the rest of your post.
Old 10-08-2009, 03:43 PM
Boston Driver's Avatar
Did you make sure the drains under the battery tray are clear of debris? That is a common source of water int he passenger footwell. You would need to remove the battery, and remove the tray on which the battery sits to get at the drain in question.
Other sources include:
-windshield cowl not installed properly
-clogged sunroof drains
-clogged a/c evap drain
Best of luck!!!
Old 10-08-2009, 03:46 PM
Oh, and here is a post that shows you how to get at the drain under the battery tray, and contained within this post is a link on how to remove the battery itself:
http://forums.audiworld.com/showthread.php?t=1723534
Old 10-08-2009, 10:43 PM
Jackmup's Avatar
Also check your Cabin air filter.
If it is wet then the plastic strip at the bottom of the windshield might be leaking. You need to carefully pry it out and clean the debris under it. Then push it back in. I used a light coating of silicone in the channel and used some black along the top where it meets the window.
Mine was leaking and dripping into the cabin air filter.
Old 10-09-2009, 07:24 AM
porschefan's Avatar
What ever you do fix it sooner rather than later. The transmission control module is under the carpet on the passenger side, i fried mine due to a blocked A/C drain.
Old 10-10-2009, 11:00 AM
NT70's Avatar
Default footwell water
seems to be coming from a spongey type washer just above the footwell at junction of glove box!!!
zpru127
05-02-2013 10:53 AM
FonzoB5S4
01-08-2011 08:26 PM
hdieffenthaller@gmail.com
08-06-2010 02:06 PM
madridlover
04-10-2008 04:10 PM
Propagandalf
07-21-2006 10:25 PM
Quick Reply: water in passenger footwell, help!!!!!!!!!
