Sponsored by:
Sponsored by:
turn signal problem
Old 10-01-2007, 02:07 PM
domvr6's Avatar
Default turn signal problem
I've been having a problem with my turn signals. I'll try an put my turn signals on and it'll click once then the light will just stay on. Sometimes theyll work. Seems like it works when the steering wheel is at certain positions. What could cause my turn signals from not working?
thanks
dominic
Old 10-01-2007, 04:44 PM
slee22's Avatar
Default RE: turn signal problem
Sounds like there is a problem with the turn signal stalk.
Old 10-01-2007, 05:54 PM
EnviedA6's Avatar
I had the same problem and then they just stopped working. You need to replace the hazard/emergency lightswitch, only $35. This relay runs the turn signals and the hazards. You would need to remove the rectangle plate that holds the hazard switch (all clips) and pop the switch out from it's side.
Old 10-05-2007, 09:32 AM
slee22's Avatar
^^I thought that too originally, but when he turns the steering wheel it works...thatshouldn't effect the hazard switch.
Old 10-05-2007, 09:36 AM
ORIGINAL: EnviedA6
im with you on this one
Old 10-05-2007, 09:42 AM
Boston Driver's Avatar
It is either the hazard realy (which contains the relay for the turn signals AND the hazard signal) or it is the turn signal stalk.
Here are two writeups to help you if you decide to DIY:
Hazard relay replacement: http://forums.audiworld.com/allroad/msgs/91515.phtml
Signal stalk replacement: http://www.audiworld.com/tech/elec162.shtml
Old 10-05-2007, 02:16 PM
tahoehtp's Avatar
yeah I checked it it was stalk. I cleand that up and plug it back in it works. but can't put it all the way in. so I'm gonna see if I can really clean it..
Old 10-05-2007, 02:23 PM
auditech79's Avatar
For future reference to everyone that reads this post:
90% of all turn signal problems stem from the hazard switch, even if your making a left for right turn.
Now if your getting a buzzing sound from the hazard switch 90% chance its the turn signal stalk shorting out the hazard switch, just from my experience of replacing over 500 or so hazards switches and about 50 turn signal stalks for both of these issues.
Old 10-05-2007, 02:40 PM
tahoehtp's Avatar
that's good to know next time it happens I know where to check for.
Old 10-06-2007, 12:26 PM
formulagigi's Avatar
mine was the flasher switch too
Quick Reply: turn signal problem
