Audi Q7 The Audi Q7, beauty on and off the streets. Refined styling paired with power and advanced technology.
08 Q7 Tire Noise only on Right turns
Old 02-07-2017, 08:29 AM
greg h's Avatar
Default 08 Q7 Tire Noise only on Right turns
2008 Q7 is smooth ( no steering wheel shake) going straight down the highway or turning to the left, but when you turn it to the right everything is still smooth, but the right front tire starts making lots of noise.
alignment done.. everything in spec.
new Blizaks on Q7. 20" tires ( I even rotated them)
Made the same noise in the summer with summer only tires on, and the outer edge of the tire wore off pretty good (typical)
I put it up in the air and everything is tight, cant' feel any wheel bearing play.
Both sides has about 1/8" up and down movement in lower ball joints
Could it be the right side drive shaft? wheel bearing?
140,000 miles
Still noisy
Thanks in advance,
Greg
Old 08-12-2017, 09:35 AM
greg h's Avatar
Update!!!
When turning to the right , weight is transferd to the left front, thus putting a load on the left front, I changed the left front wheel bearing.
All Quiet!!
Karaudi
06-30-2011 05:25 AM
Skythe
06-14-2011 07:06 PM
quattros4life03
09-06-2008 04:21 PM
MOGRINDE
09-11-2006 04:48 AM
Quick Reply: 08 Q7 Tire Noise only on Right turns
