Audi Q7 The Audi Q7, beauty on and off the streets. Refined styling paired with power and advanced technology.
ESP & ABS warning lights
Old 10-11-2010, 03:19 PM
cramman's Avatar
Default ESP & ABS warning lights
I just had my ESP & ABS warning lights illuminate on my 2007 Q7 this morning on my way to work. The car was braking fine so I turned off the ignition & started it again. This time they were illuminated as soon as I started the vehicle. Any insights as to what might be happening? Has anyone else experienced this? Any feedback would be greatly appreciated prior to taking the car in for service.
Old 10-18-2010, 07:53 PM
A84ADATE's Avatar
mine does that from time to time, as a matter of fact they are on now. 2004 A8L
Old 11-28-2010, 11:01 PM
silverd2's Avatar
Go get your codes read...could be failure in the elec module on your ABS hydraulic unit. Can be repaired (not at dealer) without replacing the entire unit.
If they've EVER been on, there's a reason and a fault code is stored.
Old 11-29-2010, 09:50 AM
A84ADATE's Avatar
It was the ABS sensor on the left rear wheel that was damaged by the wheel bearing that came out.
Old 08-16-2014, 03:52 AM
ericoQ7's Avatar
hello folks!
this seem interesting.
the ESP light has come on on my Q7 for a week now. everything seem to work fine.
i went to audi specialist yesterday and was told my ABS need changing. cost £2100 i nearly colaspe.
please were can i repair the Q7 - 2007 ABS system?
Old 09-26-2014, 11:13 AM
bab2013's Avatar
I am interested in this topic as well. Does anyone have any feedback?
Old 09-29-2014, 09:32 AM
A84ADATE's Avatar
Is it your Bosch ABS control module they are referring to? If so, you can have yours rebuilt for a fraction of that cost; I had mine rebuilt a couple years ago and works fine.
Old 10-01-2014, 10:47 AM
bab2013's Avatar
Do you have a recommendation on someone doing this? I have a 2007 Q7 that I need an ABS module (rebuilt) for. Thank you!
Old 10-02-2014, 02:30 PM
ericoQ7's Avatar
hello everyone.
my Q7 still have the ABS problem.
i did contact sinspeed they cote me £400 if i can remove the ABS and send to them. if i take the car to them it will coast me £550. i wonder if i can remove the ABS as i have now locate exactly where it is on the car.in case i remove it, what is the impact on the hydrolic system? would i have to do anything when refitting it back? your advice will be welcome
thanks
Old 10-03-2014, 10:34 AM
A84ADATE's Avatar
From what I have read, you can still drive the vehicle, however some components will not function but driveable. Your gauges (i.e. tach, Speedo, Fuel) may not work, Air Suspension dampering, steering may be stiff, brakes stiff etc.
If you get your original rebuilt, it will not have to be programmed by dealer; however, if you opt to purchase a different ABS module it will have to be programmed by the dealer for your specific vehicle.
I hope this helps, this was my experience when I replaced mine.
Quick Reply: ESP & ABS warning lights
