Audi emblem removal
Old 07-06-2007, 11:36 AM
moeron7's Avatar
Default Audi emblem removal
Is there a way to remove the audi ring emblem from the frontgrill so I can paint it?
Old 07-06-2007, 11:45 AM
diehlryan's Avatar
Default RE: Audi emblem removal
just mask around it and paint. thats what I did.
Old 07-06-2007, 11:59 AM
.clipse's Avatar
SoCal Crew Member
^wha paint did you use?
Old 07-06-2007, 12:08 PM
diehlryan's Avatar
I used Testors Model Paint (Flat Black and some Clear Coats.) It chips pretty frequently (lots of highway miles) and I use a touch up paint, bought from auto store, that matches the body paint and applys via a small brush like fingernail paint to fill in the chips. Its now mostly the touchup paint.
People have had luck with Plasti-Dip (think thats right) but its more of a flat black look.
Old 07-06-2007, 12:10 PM
cincyTT's Avatar
I'm make believe
if you use the kyrlon spray it should bond better. It is what i have on my wheels and it has more than held up.
Old 07-07-2007, 07:50 PM
.clipse's Avatar
SoCal Crew Member
oh ya, did you have to sand the rings down? apply primer? thanks.
Old 07-07-2007, 08:03 PM
cincyTT's Avatar
I'm make believe
if you sand it the paint has more to grab on to. you can primer it if you wish, but i think if you use the krylon spray you really dont need to.
Old 07-07-2007, 11:49 PM
p1zl3's Avatar
I got the rings off my front grill pretty easily... It just popped off with a slotted screw-driver and a little effort. Painting should be a breeze after removal. Just give it a quick buff with some fine-grit sandpaper and do a few light spray coats... and BOOM! New look.
Old 07-08-2007, 01:49 AM
Jays TT's Avatar
or you can use a grey scoch bright scuff pad and some Bull Dog Plastic Adhenison Promoter then your paint over that Always gotta sand .. its gotta have something to grab. The rings pull right off with a small flat head screwdriver :-)
Old 07-08-2007, 06:37 PM
.clipse's Avatar
SoCal Crew Member
^ whew alrite. thought it was molded onto the grill
Quick Reply: Audi emblem removal
