overhead dome light, no worky
So I noticed tonight my overhead interior lights were not working. I know there are 3 seperate bulbs up there but are they all on the same fuse? because when I played with the center on/off/default switch nothing happened, but if I pressed the map lights on either side, they both worked [>:]
any clue whats up?
any clue whats up?
RE: overhead dome light, no worky
mine does that occasionally. It was like that for a few months... and it just came back on last night. No clue what it is, maybe a loose connection inside the fixture I would imagine. Haven't had a chance to pull it off and check it all.
mine just got funky like that too. Flick it good and hard and sometimes it turns on, other times no. Theres a timer/switch up in there I believe, and it's either got a bad connection, or its going bad.
Hey, I have the same problem with my dome light. I thought it was a fuse, went and checked it, no luck fuse is good. The lights on my radio and red light under the radio do not work either....what gives
Mine the same. I just recently tried taking it apart to see whats up. turns out mine is somekind of short. I had the doors open, lights turned fully on, not automatic. No lights, so I started pulling the fronts, and just with a little force, bam they came on. Shut the doors, turned them on automatic again, nothing. Nothing with them fully on, and then I pulled again and they came back. Point is, Im almost positive it is some sort of short. Ex Girlfriend had a Passat, she took hers to the dealer for similar problems and they just replace the whole thing.
