quick questions
Old 08-31-2007, 12:29 AM
themysteryman83's Avatar
Default quick questions
What are the symptoms of a bad n75 and/or a bad dv?
Thanks!
Old 08-31-2007, 12:33 AM
cincyTT's Avatar
I'm make believe
Default RE: quick questions
the dv honks like a goose and leaks boost. Best way to test is to take the cover and filter off the airbox and run it around the block, if it honks, its dead. Also if it releases before you shift, its dead. As for the n75, thats harder to diagnose. Its usually when you tried everything else its the problem, but that doenst happen as often as you think
Old 08-31-2007, 09:05 AM
How about when I push the car a little harder than normal and when I let off the accel to shift it keeps boosting and revving. Sometimes it pushes the rpm to redline when it should have cut off at ~5000. It kinda scary actually. I'm wondering if this is due to a stuck open valve?
Got a good source for n75 "J" valve? I was planning on replacing it anyway. The vag-com said it's gone through its duty cycle.
Old 08-31-2007, 09:09 AM
diehlryan's Avatar
ORIGINAL: themysteryman83
Sounds like a good cleaning of the throttle body is in order.
Old 08-31-2007, 11:28 AM
cincyTT's Avatar
I'm make believe
your syptoms arent a dv problem. its staying closed if your building boost and still revving. Could be a tb problem like ryan said. clean and adjust it and hopefully it will go away
Old 08-31-2007, 04:38 PM
MeanAudiA6's Avatar
also check that line that is on top of the throttle body...controls the actual "butterfly type" valve inside of it
Old 08-31-2007, 04:46 PM
cincyTT's Avatar
I'm make believe
The tb is controlled by electronics connected to the peddle. DBW= drive by wire.
Old 08-31-2007, 08:55 PM
I already cleaned out the tb. It's shiny and good as new. I readapted it using the vag-com. 1stsensor was 10.9% (closed)second was 88.5 (wot). Does that sound about right?
Big question here... Does the TT have an idle stabilization valve like all other cars? I have not been able to find any reference of it anywhere.
tgiblin
03-18-2008 01:52 PM
01AudiA4
12-21-2007 11:22 PM
Harlemz4_Os
08-09-2007 03:32 AM
getboosted84
04-05-2007 10:02 AM
TurboQuattroPwr
09-08-2006 03:04 AM
Quick Reply: quick questions
