Fuel trim: Bank 1 : System too lean
Old 05-03-2010, 10:45 AM
yuriy's Avatar
Default Fuel trim: Bank 1 : System too lean
Well my car recently went into limp mode so a friend of mine scanned it for me and this is what it came up with: Fuel trim: Bank 1 : System too lean (sorry, i lost the actual code) I already replaced the o2 censor but the problem came back. My guess is its a faulty MAF. Is there any way to test the MAF? Thanks.
Old 05-03-2010, 12:39 PM
Dallas09's Avatar
Look for a leak in a vacuum line. Not sure about the MAF, unless you have a VAG you can see if you are getting good readings with a VAG COM.
Old 05-03-2010, 04:04 PM
yuriy's Avatar
I doubt its a vacuum leak, as my boost gauge shows around 20 to 21 inHg during idle, which if i recall correctly is where it should be at.
daveck2
09-24-2009 05:40 PM
waveblaster200
09-26-2008 03:04 PM
Sp33d07
08-14-2008 01:27 AM
vendingman2000
02-03-2007 05:10 PM
gcain99
08-12-2005 12:40 AM
Quick Reply: Fuel trim: Bank 1 : System too lean
