No interior lights at all
Just got done diagnosing a problem with my auxillary cooling fan and when I got everything put back together I find I have 0, as in none, interior lights. I ran a complete VCDS and here are the results.
01367 Central locking pump run time exceeded, likely leak
01371 Alarm triggered by door contact switch driver's side
01374 Alarm triggered by terminal 15
01370 Alarm triggered by interior monitoring
00991 Interior lights
00955 Key 1 adaptation limit surpassed
00956 Key 2 adaptation limit surpassed.
The odd thing is this same test was run last week while looking for a solution to the cooling fan problem and produced the same results but nothing changed until today.
The central locks still work just fine although I can hear the pump very well.
Any ideas on where to start? I can access the pump easily since this is an Avant.
Thanks for any suggestions.
Can you please school me on where to find that switch?
Yea you're probably looking for some little plunger thing in the door jamb. It's actually two little microswitches built into the door latch. You have to take off the door panel and you'll see a little plug at the door latch.
Okay, no plunger switches on either front door or the tailgate. However there are plunger switches on the passenger, rear, doors. It's an Avant BTW.
I'm confused but guess I'll pull the central locking system pump gizzo and see what's in there.
Fuse # 14 fell out DOH
Now I fell pretty stupid. I went to re-check the fuses and sure enough # 14 was missing. It must have fallen out while I was working around there. Problem solved and thanks for the input.
