P1136, P1138? BAD ECU?!? HELP!
Old 02-12-2008, 09:04 AM
plblevins's Avatar
Default P1136, P1138? BAD ECU?!? HELP!
I have a 1999 Audi A4 (2.8). I tookmy car to Autozonefor them to run the OBDII turns out the tech there thinks I have a bad ECU. Is that possible? Codes ran where p1136, and p1138. I read it could be avacum leak. Any ideas??
Old 02-12-2008, 02:31 PM
CRAZYHAWK's Avatar
Default RE: P1136, P1138? BAD ECU?!? HELP!
Check all the vacuum hoses.
Old 02-12-2008, 02:38 PM
P1137 is the problem EVAP canister purge valve and as stated an air breach in that system
Old 02-12-2008, 05:38 PM
powersmokin's Avatar
when the ECU is most of the time the car will not run at all .
Old 02-13-2008, 12:12 PM
plblevins's Avatar
Thanks for all the replys. I'm going to go over my vacum hoses this weekend. How can I tell if my MAF is bad? Is the EVAP canister purge valve expesnive to replace/fix? Can I do it or does a dealer need to?
grease
08-16-2014 05:45 PM
ChadAudiA6
01-16-2010 08:44 PM
milo55041
05-30-2009 12:53 PM
plblevins
02-13-2008 10:03 PM
plblevins
02-12-2008 10:08 PM
Quick Reply: P1136, P1138? BAD ECU?!? HELP!
