spike and drops in timing
Old 05-23-2013, 10:25 AM
moneyfresh's Avatar
Default spike and drops in timing
Havin a rough idle, spikes and drops in timing, cam chain tensioner?
Graph of logs
https://www.audiforums.com/forum/att...2&d=1369272364
Old 05-23-2013, 01:40 PM
redline380's Avatar
Legal Moderator
any codes?
Old 05-23-2013, 06:16 PM
moneyfresh's Avatar
Second 02 and sai i have testpipe, and sai delete
Old 05-25-2013, 03:14 AM
redline380's Avatar
Legal Moderator
its really hard to say. maybe a video would help. theres so many things that it could be, but because timing is controlled electrically, i would sway towards it being an electrical issue.
Old 05-26-2013, 04:02 PM
moneyfresh's Avatar
Old 05-27-2013, 01:51 AM
redline380's Avatar
Legal Moderator
it definately sounds a bit clanky to me. you're not offering a ton of information, but based on what i have i would pull the valve cover and check it out. maybe have a a friend start it and let it run for a couple seconds with the vc off if you dont mind a little oil squirting.
but.. how did you perorm the sai delete? i need details on this. one wrong move could be your issue
Old 05-27-2013, 06:56 AM
moneyfresh's Avatar
I havent done the full delete just yet the sai is just unplugged at the moment, everything still connected, i have cleaned throttle body, cleaned iat and maf sensors, done the throttle body adaptation, going to try plugs tonight, if i have time i will run with valve cover off and send you a video, would a bad second o2 be the cause?, i ordered the timing chain tensioner without thinking, and might return, only if its a mechanical part, audi doesnt return electrical aha
Old 05-29-2013, 05:48 AM
moneyfresh's Avatar
Past 2 days after work my car battery has been dead, the battery was toast and wasent charging, new battery covered by warrenty all fixed, thanks for the help!
jesse86
S4
09-28-2013 10:34 PM
masterforu2nv
06-21-2007 07:48 PM
davism1
03-15-2007 11:14 PM
b.hasz
02-10-2007 03:17 PM
Dstranks
09-05-2006 03:11 PM
Quick Reply: spike and drops in timing
