21 pound spike to high?????
Old Mar 14, 2007 | 09:59 PM
davism1's Avatar
Default 21 pound spike to high?????
is 21 pound spike holding 19 psi too much for K03s? i dont no if its the warm weather or my new turbobackor what but my boost has gone up about 3.5-4 pounds? and i dont want to rush blowing my k03s just yet.
Old Mar 14, 2007 | 11:46 PM
S4evr's Avatar
Default RE: 21 pound spike to high?????
it is probably the turboback. The added psi will have an effect on turbo life, but it shouldnt matter that much
Old Mar 15, 2007 | 12:56 AM
2k S4's Avatar
I would run some vag-com logs on block 115, something is not right, you should not be boosting that high.
Yes, you are over spooling the Turbo's & they will not last long. Your exhaust should have nothing to do with boost.
My guess is you have a N75 problem, or something wrong with the wastegates.
Old Mar 15, 2007 | 01:06 AM
davism1's Avatar
if there is somthing wrong with the n75 valve would it show up on a regular scanner or no?
Old Mar 15, 2007 | 01:07 AM
S4evr's Avatar
well, a full turboback does help spooling, and if the cats were bad enough it could raise boost pressure. then again, i dont think it could raise it that much.
Old Mar 15, 2007 | 01:16 AM
davism1's Avatar
i dont have cats anyway im thinking i might just do a mbc to be safe
Old Mar 15, 2007 | 01:46 AM
2k S4's Avatar
ORIGINAL: davism1
No cats has nothing to due with it. You still need to set up a MBC, it's only going to be a band aid on the real problem.
Old Mar 15, 2007 | 01:49 AM
davism1's Avatar
maybe ill try the n75 valve? what could have gone wrong with the wastegates?
Old Mar 15, 2007 | 06:24 PM
2k S4's Avatar
ORIGINAL: davism1
There might be a leak in the lines, or the accualtores are sticking.
Old Mar 15, 2007 | 07:24 PM
davism1's Avatar
are my wastegates internal?
