B6 Audi A4 - ABS + EPC + MIL Lights On - Please Advise
Old 03-27-2011, 02:13 PM
js2724's Avatar
Default B6 Audi A4 - ABS + EPC + MIL Lights On - Please Advise
Hi Everyone, this is my first post on AF so please take it easy on me if i'm not following any specific format.
I have tried to search the forums for my exact issue and while there were some good "finds" there wasn't a direct solution to my problem.
Now on to what i'm "experiencing".
The check engine light, ABS, and EPC lights are on at the moment. Sometimes the EPC + ABS lights go away (when they do go away, the go away together) and the check engine light will remain . When the ABS and EPC lights come back on, the speedometer stops working ( stays at 0mph). The speedometer will work if the ABS + EPC lights are gone but the check engine is present.
I had the codes run and the first time i got this error code:
P0501 - ABS Speed sensor left front
I bought this part and replaced it.
Now all 3 lights are back and i ran the codes again:
P0501 - Vehicle Speed Sensor A - Range
The exact vehicle is 2003 Audi A4 3.0L V6 Quattro.
My initial guess is that i need to replace this part.
I thank all of you in advance for your expert assistance. This is my first audi ( love the car) but don't want to endlessly try to troubleshoot it.
Old 01-23-2012, 10:45 AM
tnsparky's Avatar
js2724 Did you ever find any info on your problems? I'm having the same problem check engine light on, abs+epc on, and p501 vehicle speed sensor code. Same car 2003 audi a4 v6 quattro. I have replaced speed sensor inside transmission but speedo work but back out. I remember reading somewhere that all this might be a problem with ECU.
Old 01-23-2012, 10:55 AM
js2724's Avatar
Hi yes I finally fixed the problem. It was the abs module computer that was faulty. Check out these guys module masters (quick google search will pull them up). They offer a mail in service.
I went to so many mechanics without luck. Finally Greg over at germanautorepairs.com was able to diagnose and solve the problem for me. I highly recommend him if you are in long island, ny.
Hope this helps
Old 01-23-2012, 11:04 AM
tnsparky's Avatar
I'm in TN but mail in service would work, I will check it out. Thanks
nize
06-21-2013 01:16 PM
woolveren
09-05-2011 03:13 AM
woolveren
08-29-2011 10:24 AM
MacAngus
09-17-2010 11:10 AM
Huaren
12-28-2006 04:16 PM
Quick Reply: B6 Audi A4 - ABS + EPC + MIL Lights On - Please Advise
