engine swap
Old 05-05-2008, 09:19 PM
02audia41.8's Avatar
Default engine swap
does anyone know if its possible that i could switch a 1.8t to a v6 2.7t and how much it would all be
Old 05-05-2008, 09:30 PM
amiller86's Avatar
Default RE: engine swap
You may have problems getting the 2.7 in the bay with that divider in place. (You know the wall between the engine and the battery, ecu, etc.) Also you would want to consider what adding that much weight up front will do to your car. Def think about suspension work if you actually plan to do this. Price will depend on where you get the engine..
Old 05-05-2008, 10:23 PM
do you know where i could get the engine i havent been able to find anywhere
Old 05-05-2008, 11:19 PM
how hard will it be to swap the engines and has anyone had experience with this same swap any problems ???
Old 05-06-2008, 09:38 AM
amiller86's Avatar
there are national engine remanufacturers, but i've never used any of them and wouldn't be able to recommend a particular one. i would try and work as close to home as possible; maybe check out some auto recyclers. you may have to get the engine in pieces. finding a block in working condition would be a good place to start..
this was really the only other thread i found about this (no real info though)
https://www.audiforums.com/m_414905/tm.htm
Old 05-06-2008, 11:09 AM
thanks
rwhaley205
03-01-2014 10:31 PM
curtmon03
03-19-2012 08:35 PM
curtmon03
10-04-2011 07:49 PM
lacadie17
07-11-2010 08:06 PM
8urVtec
03-11-2006 08:40 PM
Quick Reply: engine swap
