engine swap
Old May 5, 2008 | 09:19 PM
02audia41.8's Avatar
Default engine swap
does anyone know if its possible that i could switch a 1.8t to a v6 2.7t and how much it would all be
Old May 5, 2008 | 09:30 PM
amiller86's Avatar
Default RE: engine swap
You may have problems getting the 2.7 in the bay with that divider in place. (You know the wall between the engine and the battery, ecu, etc.) Also you would want to consider what adding that much weight up front will do to your car. Def think about suspension work if you actually plan to do this. Price will depend on where you get the engine..
Old May 5, 2008 | 10:23 PM
do you know where i could get the engine i havent been able to find anywhere
Old May 5, 2008 | 11:19 PM
how hard will it be to swap the engines and has anyone had experience with this same swap any problems ???
Old May 6, 2008 | 09:38 AM
amiller86's Avatar
there are national engine remanufacturers, but i've never used any of them and wouldn't be able to recommend a particular one. i would try and work as close to home as possible; maybe check out some auto recyclers. you may have to get the engine in pieces. finding a block in working condition would be a good place to start..
this was really the only other thread i found about this (no real info though)
https://www.audiforums.com/m_414905/tm.htm
Old May 6, 2008 | 11:09 AM
thanks
rwhaley205
Mar 1, 2014 10:31 PM
curtmon03
Mar 19, 2012 08:35 PM
curtmon03
Oct 4, 2011 07:49 PM
lacadie17
Jul 11, 2010 08:06 PM
8urVtec
Mar 11, 2006 08:40 PM
