How do I check for vacuum leaks????
Old 05-29-2008, 09:29 AM
Audinick81's Avatar
Default How do I check for vacuum leaks????
My car seems to be running fine, but i notice when i'm stopped at a light, sometimes there is a slight vibration and sometimes that car is soo smooth you can't even tell it's on... I did fix a busted air hose..... did it myself, but I want to make sure that there isn't another leak, is there a DIY method to determine any possible leaks?
And after you fix the leaks, is it necessary to reset the ecu box even if you already cleared the codes?
Old 05-29-2008, 03:25 PM
EVOLA4's Avatar
Default RE: How do I check for vacuum leaks????
This should be exactly what you are looking for http://www.a4mods.com/index.php?page...boostleak.html
Old 05-29-2008, 03:29 PM
The Orange Remix's Avatar
Is a vacuum leak the same as a boost leak?
Old 05-29-2008, 03:36 PM
Audinick81's Avatar
ORIGINAL: EVOLA4
Thanks for the link, it was interesting, but i have a 6 cylinder Turboless car
Old 05-29-2008, 04:57 PM
guitarc's Avatar
Couple ways I used to check for vacuum leaks. Get about 3' length of heater hose or garden hose, put one end at your ear and the other end at each connection and listen for a change in pitch.Or take gas and put in a dropper and drip gas on the connections. Engineidlewill pick up when you find a leak. Uh with the computer controlled cars it may slow down some......any way it will change. Both crude but work.
Old 05-30-2008, 12:39 AM
EVOLA4's Avatar
Sorry, I didn't see your sig... I just assumed everyone drives a 1.8t because it seems like most people on here do. Good luck
Lmal355
04-25-2011 07:36 AM
krishna.poda
02-16-2010 08:54 PM
shoveland
04-08-2009 12:54 PM
michaelh305
08-01-2008 09:55 AM
quattro/2.8
05-13-2007 02:13 AM
Quick Reply: How do I check for vacuum leaks????
