Throttle position sensor problems
Old 12-19-2011, 12:04 PM
trunk999's Avatar
Default Throttle position sensor problems
Hi,
I broke down last week (no acceleration, esp & ignition coil warning lights on) and problem was diagnosed as the throttle position sensor. Tested and repaired and all was ok until same problem has just occurred again. Any ideas on a cause gratefully received?
Old 12-19-2011, 12:05 PM
trunk999's Avatar
Default model
Car is A4 2.5 tdi convertible (04)
Old 12-31-2011, 05:38 AM
saucy05's Avatar
I would take a closer look at the engine control module. I had the same issue and my mechanic found one of the pin that connected to the ecm was bent and wasn't able to relay the throttle sensor information.
Old 12-31-2011, 09:22 AM
trunk999's Avatar
FYI I've replaced the engine ecu cover and (touch wood) haven't had a recurrence yet............
spit144
04-04-2020 10:30 PM
spit144
10-26-2010 04:52 PM
IshTerp
10-30-2008 12:05 PM
brijan
02-15-2008 08:48 PM
audi_pa
11-04-2006 09:39 PM
Quick Reply: Throttle position sensor problems
