Whining fuel pump?
Old 10-29-2008, 02:32 PM
NJHitman's Avatar
Default Whining fuel pump?
2004 A4 Quattro.
I have a loud (in the cabin) whining eminating from the back seat area. I'm thinking that this is probably the fuel pump.
The whine doesnt change pitch with a change in RPM's.. it is constant.
Opinions please...
NJHitman..
Old 10-29-2008, 04:53 PM
pa4ul's Avatar
either ur pump is going kaput or well do u have a sound system?
Old 10-29-2008, 06:15 PM
audiprotein's Avatar
As far as i know, it suppose to make the sound under the load. does it make that sound at idle? Try to touch your fuel lines, if they are shaking- that would be either filter or pump (or both).
Old 10-30-2008, 08:22 AM
docurley's Avatar
Well I would say you might need to change the fuel filter it may be blocked up a little making the pump work over time or it's already killing/killed the pump.
Old 10-30-2008, 10:41 PM
Bltprf502's Avatar
I just ordered a fuel pump for mine today. It was doing the same thing. I am pretty sure the pump is going bad...
Old 10-30-2008, 11:49 PM
What year is your car? There was a recall for 03 models (not every). Call AOA or any dealer, give them your vin and see if your car under the recall. If yes, they have to replace your fuel pump for free.
Also, try changing your fuel filter, that might be your problem + it is much cheaper to try. Cause it is better to change the filter with a new pump anyways.
Old 10-31-2008, 09:03 AM
SrK's Avatar
SrK
SrK is offline
before changing bunch of money on the fuel pump, try getting a new fuel filter. I have 120K on my car and this happened to me twice already.
Old 10-31-2008, 07:13 PM
stutzdriver's Avatar
I had this happen on my 03 1.8T a few weeks ago. Changed the fuel filter and all is ok. Change the filter before you assume it is the pump. Parts guy at the local stealership told me this noise is supposed to happen to indicate the need for a new filter?
J Traner
2003 A4Q 1.8T
Old 10-31-2008, 09:21 PM
JoeD1346's Avatar
My car makes a whining noise too, but it's only when the tank is at about 1/8 full. Correct me if I'm wrong, but I've heard it's a royal pain in the *** to diy the fuel pump, almost to where you wouldn't even want to try it.
Old 10-31-2008, 09:22 PM
^^^Abought right, cause our pump has so called "built in" regulators.
Quick Reply: Whining fuel pump?
