Audi A4 B7 Cruise Control Issue
Hi, all new to the forum. Just wanted to give a little background about myself. I just recently sold my Infiniti G35 Coupe wanting to get something with a little more space. I recently purchased an Audi A4 2006 6 MT with 61k miles immaculate condition. However there is one small problem. The cruise control does not work.
I have read threads on this subject on the AudiWorld, and AudiForums, and was hoping someone could give me an idea that I may have overlooked.. or confirm my diagnosis.
At first I thought it could be a clutch sensor. But I notice I cannot start the car without depressing the clutch. I also do not get any weird revs. The cruise control light does not come on when I attempt to activate it. And just to make sure I get the procedure right, I pull it back toward the steering wheel and press the button to set it at speed. Nothing happens, no cruise icon light on the dash, nothing. So I assume it is a problem with the stalk? Maybe lose connections? Or is there another module I need to take a look at? I am savy with electronics, however, I dont like to take things apart without knowing generally what is going on. Can anyone provide any input?
I tried doing what you said recently, and pushed with at least 3-5 pounds of pressure at that one spot. Nada.
Another question for you guys is, are all of the cruise controls electronics isolated to the stock? I'm thinking oxidized connections and the like...
Is there was a way to do a positive test electronically, or otherwise to ensure the switch was sending the signal?
Hmm... so two clutch sensors... So basically the depressed sensor could be working, however the "out" sensor may not be. Interesting theory. Now can the cruise control "On" light come on without actually setting it? I had a car that did that, but until you engaged it, the function doesnt work. If thats the case, with this car, then at least I can isolate it to the actual ****.
