: ECS Tuning :: NEW!! ECS Luft-Technik Intercooler System | Audi B8 A4/Allroad 2.0T
The ECS Luft-Technik Intercooler and Charge Pipe System was designed and engineered in-house to provide you with a direct bolt-on system to increase air flow, decrease restrictions, intake temps, and most importantly increase power!
ECS Tuning's Luft-Technik Intercooler features a 21x9x3 aluminum bar and plate core with cast aluminum end tanks which uses factory mounting locations, so that no trimming or cutting is necessary. This makes installation completely reversible, creating a system to optimize performance and provide the clean look that Audi owners have come to expect.
Key Features:
- Reduced intake temperatures and air turbulence. (Up to 40% improved intercooler efficiency reduced intake temps by as much as
65*F during solid state WOT loading.) - 52% reduced pressure drop
- Increased air flow capacity
- Gains of up to 13 WHP and 10 Ft-Lbs WTQ over APR Stage 1
- Cast aluminum intercooler end tanks
- Bar and plate design intercooler core
- 2.50" diameter intake tract
- 4-ply silicone straight/hump couplers
- Aluminum tubing powder coated in a tough wrinkle black finish
- OEM like bracket secures the throttle pipe in place
- CNC machined MAP flange welded to factory position
- Eliminates the factory noise pipe
- Includes all stainless steel t-bolt clamps
- Easy and direct replacement upgraded system
Gains of up to 13 WHP and 10 Ft-Lbs!
Click HERE to order or for more information
Fits:
Audi B8 A4 2.0T 2009-2016
Audi B8 A5 2.0T 2008-2016
Audi B8 Allroad 2.0T 2013-2016
Be sure to check out our ----> Installation PDF <-----
Let me know if you have any questions.
Jason
ECS Tuning
S3
02-15-2017 04:21 PM
ECS Tuning
02-15-2017 04:20 PM
ECS Tuning
B8 Models
01-04-2016 12:46 PM
ECS Tuning
S4
11-19-2015 10:37 AM
ECS Tuning
S5
11-19-2015 10:36 AM
