1984 5000s - Changing/checking manual transmission oil
Old 12-14-2006, 06:54 PM
Phaedrus44's Avatar
Default 1984 5000s - Changing/checking manual transmission oil
Hi group-
My owner's manual tells me that my transmission contains hypoid gear oil that doesn't need to be changed. I don't believe it. Where is the check/fill plug in my 5000s' 5 speed transmisison, and what do you guys reccomend I fill it with? Thanks!!!
Old 12-15-2006, 04:19 AM
mattr7786's Avatar
Default RE: 1984 5000s - Changing/checking manual transmission oil
well if your manual says that then it is fine ...i have no idea you dont see alot of those cars i had a 92 audi 100 and thats the oldest ive seen in a couple years
Old 12-15-2006, 10:06 AM
the tranny is filled for life unless you sprung a leak, there is a bolt on the side for topping up, the 4000/5000 are the same as the 200/100 series in the UK the 200 being the turbo
joesaudi1
06-29-2015 11:51 PM
olsonm3915
05-16-2008 08:11 AM
TuckerGgener
01-05-2007 09:34 PM
Phaedrus44
12-06-2006 04:46 PM
xmishx
12-10-2005 06:37 PM
Quick Reply: 1984 5000s - Changing/checking manual transmission oil
