Can't find the DIY you want? Click here
This is for the noobies and members that haven't learned how to use the display option yet. Since the forum layout changed, it may seem like some of the threads have disappeared into thin air. This isn't the case. At the bottom of each section (including the DIY section) there is an option that says Display options. When in the DIY section select "from the beginning" to access all the DIY's posted on the forum. You may only see a couple when you first select this section, so you have to adjust the seach. Sorry if the forum layout is stupid, i didn't design it.
