click, click, click when started from cold
Old Nov 8, 2007 | 05:32 PM
gregorywrites's Avatar
Default click, click, click when started from cold
OH, I WISHsomeone could identify the cause of this problem. Here's the story: 2002 TT 1.8 Turbo 20V Quattro roadster.January, 2007, 50k miles--when the engine is started from cold (first thing in the morning), and after it idles (1,200 rpm) for about 2 minutes, a click, click, click noise arisesfrom the front of the engine (passenger's side of car) and the clicks are happening about once every second. If you wait a few minutes for the engine to warm up (idle drops to 900 rpm) the clicking slows to about once per second. If you drive the car about a mile, the clicking is gone. If you start the car every few hours during the day, no clicking. But keep reading, there's more ...
I took the car to the dealer (Roger Jobs in Bellingham, Washington); they thought it was the serpentine belt and replaced the belt, but the noise was still there. June, 2007: car in for oil change; I told the service rep that the noise was still occurring; they couldn't find problem. October, 2007: I left the car with the dealer for 3 days. They took a lot of stuff off the front of the engine, but were unable to find the problem.
NOVEMBER, 2007, 65k miles: a few NEW DEVELOPMENTS: after starting the car cold in the mornings, the clicking arises in about 30 seconds (you no longer have to wait a couple minutes), and the clicking is now at rate of about 3 or 4 times per second, and sounds more like click CLICK click ...click CLICK click ... click CLICK click ... In a few minutes the engine warms up, the rpm dropsfrom 1,200 to 900, and therate of clicking slows. If you drive a couple miles, the noise is gone. If you park the car and start it again 3 or 4 hours later, no noise. If you park the car at 8 a.m. and start it again at 4 p.m. (the engine is cold) you will get the noise.
One theory being discussed is timing belt problems, but why would the noise require time (30 seconds) to appear, and why would noise go away after driving a mile or two? Another theory is sludge build up in the 1.8 20V turbo engine. The dealer wants to try engine flush. Another theory is faulty pressure check valve.
DOES ANYONE HAVE EXPERIENCE WITH THIS? CAN ANYONE DIAGNOSE THIS PROBLEM?
Please post here, or send e-mail to gregorywrites@yahoo.com
OH, PUH-LEEEEZ !!!
Greg
Old Nov 8, 2007 | 05:46 PM
WishIWasRWD's Avatar
Default RE: click, click, click when started from cold
It may bea midget with a typewriter in your airbox.
How else do you suppose the outside temperature, CD track, MPG, etc get displayed on your dash, Magic?
He may take a little while to get started because he is a union worker. They usually don't start working until they are on the job for about 45 minutes. He must bevery ambitious.
Old Nov 8, 2007 | 06:22 PM
socaljoe's Avatar
SoCal Crew Member
Same thing happened to my truck, loud clicking at start up and lessens when it has warmed up. It was almost like a very loud valve slap sound, turned out that my catalytic converter was falling apart. Noise went away after the cat. converter got replaced.
slopoke
Mar 11, 2010 12:16 PM
chocalotstarfish
Feb 4, 2010 03:29 PM
gregorywrites
Nov 10, 2007 11:17 AM
gregorywrites
Nov 8, 2007 06:17 PM
gregorywrites
