+ ABS & ESP LIGHTS ON DASH
Old 07-07-2005, 10:46 PM
CRAZYHAWK's Avatar
Default + ABS & ESP LIGHTS ON DASH
I had the car vaged and have the following
DTC 18265 P1857-35-0 LOAD SIGNAL - ERROR MESSAGE FROM ECU
What does this mean?
Old 07-08-2005, 06:43 AM
audiscientist's Avatar
Default Sensor
Sounds like one of the ABS senors has broken down if you have access to VAG this can be tested. Go into
brakes 03
Read measured value blocks 08
001
this will display the readouts of the ABS sensors for all four wheels, then just drive the car while monitoring the read outs and see if any are diffrent to the rest. If so the ABS sensor requires replacment.
Old 07-08-2005, 10:39 AM
CRAZYHAWK's Avatar
Default RE: Sensor
Thanks, I'll let the guy who Vaged my car know.
Old 07-15-2005, 12:39 PM
CRAZYHAWK's Avatar
Default RE: Sensor
Last weekend, I removed each wheel and hit each brake caliper lightly with a one pound hammer. I freed the dust on the wheel sensors and now the ESP and ABS work. The dash indicators went out after being reset with a computer.
Old 08-09-2005, 09:20 PM
CRAZYHAWK's Avatar
Default RE: Sensor
This is for nirvana.
nize
06-21-2013 01:16 PM
SAudi
08-20-2009 11:36 PM
sam.hollis
02-14-2008 11:36 PM
blockp
01-30-2008 01:04 AM
alan93
07-06-2007 09:49 PM
Quick Reply: + ABS & ESP LIGHTS ON DASH
